what tunes should i get - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-14-2014, 09:56 PM Thread Starter
i have a 2004 6.0 that is studded, deleted, and upgraded. i have straight exhaust and am possibly thinking about getting a water/meth injection. I have an sct whith tunes from mpt just becuase thats who i bougth it from but i think i already have my daily driver tune so i am trying to find the highest hp tune to race with so what tune are you using and also what do you think about the water/meth and about how much hp increase have you seen
6.0Beast is offline
post #2 of 3 Old 02-15-2014, 09:42 PM
turbotibbo's Avatar
Try out gearheads srlxx tune or tsd spd tune , ther is also quick tricks , dp tuner php , and the list goes on and on , it all depends on what stragety u are running and what the truck itself likes , my fav is Matt at gear head and the super panty dropper from truck source diesel , hope this helps , should see 400 -425 hp with your set up
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #3 of 3 Old 02-15-2014, 09:52 PM
COONASS
WHAT HAPPENED's Avatar
Dont forget to look at PHP $60 = 140X Can't be beat
And you can also add there Atlas 40 or 80 or 100 on top of that
Also fill out your sig with the mods on your truck so you dont have to explain them to us every time
2005 CCLB FX4
ARP, EGR Delete, 5 inch TB, SCT Livewire, Sinister Coolant filtration, ECL-1, PHP TUNES
Federal Ownership Respectfully Declined
WHAT HAPPENED is offline
The Following User Says Thank You to WHAT HAPPENED For This Useful Post:
Chatham036 (02-15-2014)
