My truck breathes so much better. - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By weswanson
post #1 of 2 Old 02-14-2014, 06:41 PM Thread Starter
I have a 03 F250 super cab with 101,200.00 miles on it. I bottomed out last year and crushed my exhaust as it straitens from the turbo down pipe. This cracked and exhaust was getting into the cab at standstill.
I ordered a Diamond eye off road turbo back 4" SS system. That went on with some pain, sounds nice and I can feel the extra power. Next I installed a Gforce chip, and spray cleaned my MAF sensor. Lastly I installed a Ingen cold air intake system. I will say this. My truck now breathes with excellent throttle response. I will see if my mileage improves. You would thing it would. Most of the time it stays the same with lots of added power.
ODAWG714 likes this.
weswanson is offline
post #2 of 2 Old 02-15-2014, 08:35 PM
turbotibbo's Avatar
Right on man glad she worked out for ya
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
