Rear Shackle Flip ? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-14-2014, 11:58 AM Thread Starter
colonel angus's Avatar
Quoted: 2 Post(s)
Rear Shackle Flip ?
Instead of traction bars ......
I would like to reduce the amount of lift block I have ~6" to a stock F-250 block is the shackle flip something that would accomplish this and if so are there any sides effects or negatives? I've searched and can't find anyone that has done it to reduce Blocks....
It comes in 2.5" 3.5" and 4.5" versions......
1999-2012 Ford F-250/350 Shackle Flip Kit
I can see possibly needing a custom block so it sits level or slightly raised but that's it.
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #2 of 5 Old 02-14-2014, 12:06 PM
Brent Beeler's Avatar
Check your pinion angle before and after A friend of mine back in high school had a mid-70s Chevy and we did a shackle flip to it he had nothing but problems throwing the rear end ujoint all the time. Didn't dawn on us back then but the problem could probably have been fixed by installing a wedge between the springs and axle. Driveshaft looked straight with rear end but we never thought about what happens when you hit the throttle hard
Sent from AutoGuide.com App
Brent Beeler is offline
post #3 of 5 Old 02-14-2014, 12:08 PM
Those look legit let us know how they work out I'd like to get rid of my blocks as well
post #4 of 5 Old 02-14-2014, 01:45 PM
huck2080's Avatar
it will reduce the amount of weight you can carry , and peobably give you more axle wrap then you have check out sky mfg . they have some for superdutys that look like fabtechs front raduis arms
huck2080 is offline
post #5 of 5 Old 02-14-2014, 01:53 PM
ZMANN's Avatar
Quoted: 1469 Post(s)
Trevor makes good stuff but these aren't for me
the installation of this will move the axle forward and increase pinion angle. The larger the lift amount with this method, the greater the change. This can be corrected with adjustable location lift blocks, pinion correction shims, or a different tapered block.
We Miss you Ronnie
ZMANN is offline
