$900 68mm powermax - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-13-2014, 06:00 PM Thread Starter
powerstrokecrzy's Avatar
Quoted: 228 Post(s)
$900 68mm powermax
For sale locally. Described as a 68.5mm with only 2000 miles. Good deal? Would it be good for towing with my mods? Add said he may take less.
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is offline
post #2 of 6 Old 02-13-2014, 06:03 PM
Ordnance on coordinates
powerstrokeshellback's Avatar
Quoted: 53 Post(s)
Feedback Score: 7 reviews
are there pictures? 2k miles at 1500* is alot. need to see the condition of it. if its straight, thats a decent deal.
2007 Ford F-250 XL 6.0L Powerstroke 4x4
God bless America, the Constitution and the Second Amendment.
Archoil gangbang - don't be the soggy biscuit
powerstrokeshellback is offline
post #3 of 6 Old 02-13-2014, 07:05 PM Thread Starter
Quoted: 228 Post(s)
Here is the only pic. Is there a way to tell it is in fact a 68 pmax without taking the cover off and measuring it. At worst I can go check it out, check the wheels and shaft play.
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #4 of 6 Old 02-14-2014, 08:31 AM Thread Starter
Quoted: 228 Post(s)
Bump to top
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #5 of 6 Old 02-14-2014, 10:35 AM Thread Starter
Quoted: 228 Post(s)
Says he got it from xdp but they're website doesn't show a 68mm powermax, just the regular one 64.5mm I think. I don't know.......
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #6 of 6 Old 02-14-2014, 05:37 PM
twoicebergs's Avatar
Quoted: 43 Post(s)
Measure the intake with a caliper. If it is 68mm, then you have your answer. However, what is the exducer, 88 or 94mm?
This would be a good buy if you wanted to have a larger exhaust wheel to match the turbo more to that of a KC or Barder stage 3.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
