Street Truck Build - Ford Powerstroke Diesel Forum
 24Likes
post #1 of 110 Old 02-13-2014, 02:20 PM Thread Starter
Real Men of Genius
Super Diesel's Avatar
Quoted: 10 Post(s)
Feedback Score: 9 reviews
Street Truck Build
Alright, I need some advice. I'm looking at building my truck into a reliable and powerful build, it will never tow. I will hit the track eventually, but for the most part this truck will be doing dyno competitions. I'm not planning on building a monster engine that will win the dyno competitions, but I want something that's going to give the 6.0 props wherever I go.
The truck currently has:
ARP Studs
Machined and O'Ringed Heads
OEM Gaskets
S&B Intake
MBRP TB 5" Exhaust
MTW MadMax turbo - 11 blade turbine wheel
Beans Diesel Sump
GlowShift - Boost, Pyro, and Fuel Pressure
Edge Insight CTS
The truck is running Matt @ Gearhead's SRL+ as a daily driver, and is swapped over to the SRL Extreme for competitions. It also has the Hercules 100 FICM tune from Bill @ PHP.
This setup just put down over 500 on Dyno Proven's dyno.
The things that I know I need:
Injectors
Regulated Return
Ported Intake
Fuel System?
Traction Bars
Nitrous
DD Clutch
I've talked with Matt Wilbur about my build extensively. I had my mind set on 175/100 injectors from Warren, but now I'm hearing that my goal of 600+ fuel only, and 800 on nitrous isn't realistic with this setup. Seems the word on the threads are 3.6hp per cc - so if I want 800rwhp, then that's putting me at 225cc injectors. I'm not sure how accurate that math is, but that's what I'm getting.
One more thing, I don't want this to turn into a MTW bashing thread. I'm running his turbo, end of conversation. But I would like additional input on everything else. I've been out of the 6.0 performance world for quite some time, and things (obviously) change around here quite a bit. So... what're we thinking?
Chris | 2005 F-250 RCSB | "Ranger - Turbo Diesel V8"
CED Compounds - Conventionals - Supporting Mods
Super Diesel is offline
post #2 of 110 Old 02-13-2014, 03:21 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
I'd say 190/75, ported intake, regulated return, open intake with an AFE filter, edit" saw you had an intake... and a built trans and some Gearhead tuning will be fun a reliable. As far as turbo I'm sure the Barder stage3 or the kc68 will be a positive addition due to a larger compressor wheel adding more air into the motor. Traction bars a must! Fuel system yes! Wanna keep them sticks healthy and no need for a dd when you get a trans
As far as the dyno, I'd take that with a grain of salt. No pun intended
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #3 of 110 Old 02-13-2014, 03:38 PM Thread Starter
Real Men of Genius
Quoted: 10 Post(s)
I'm confident that the dyno is accurate.
190s huh? I had always thought about 190s, how are they as far tune-ability? Detuning for daily driving use mainly. As far as a regulated return - I'm talking to an ORG member (we all love him) about one of his kits. How are the 6.4/6.7 fuel pumps holding up for the guys that were trying that swap going? If that doesn't work well, I'm assuming the AD150 and an A1000 like usual will be the fuel system of choice?
Traction bars... this should be fun. My truck isn't the normal wheelbase, how difficult is this going to be for me to find someone to make me some?
The trans is a ZF6, so I really just need a dual disc clutch for it. The rest of the transmission is pretty stout, from what I hear.
post #4 of 110 Old 02-13-2014, 03:43 PM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
nate broke 600 on 190/100's and i dont think he had as many supporting mods as you do at the time he broke 600.
07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, Toyo MT's, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, super bright leds 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
Thanks to bigblack for selling me his truck
MyTractorsSexy is offline
post #5 of 110 Old 02-13-2014, 03:45 PM
ODAWG714's Avatar
Quoted: 6 Post(s)
I know one up offroads will work. Flight fab is another.
Me and a few members have been using an airdog150 feeding a stock pump with no issues. I hold 55 all day long. As far as tuning, most tuners tune for nozzles these days and there shouldn't be an issue
Oliver
ODAWG714 is offline
post #6 of 110 Old 02-13-2014, 03:47 PM Thread Starter
Real Men of Genius
Quoted: 10 Post(s)
What supporting mods do I have, that Nate didn't have? I was hoping to be on/over 600 with 175s - is that not possible?
post #7 of 110 Old 02-13-2014, 03:50 PM
ODAWG714's Avatar
Quoted: 6 Post(s)
It's possible, I didn't have a chance to back my 618 on 175s due to my trans but my 581 was backed at the track.
Oliver
ODAWG714 is offline
post #8 of 110 Old 02-13-2014, 03:54 PM
Quoted: 7 Post(s)
i dont think he had the ported intake ( that you said youll be getting ) when he did it not all sure what he had honestly but it might be worth a pm. i know he broke 600 on 190s
07 F250-SOLD
post #9 of 110 Old 02-13-2014, 04:10 PM
strokin6L's Avatar
Quoted: 3 Post(s)
a low pressure FASS or a airdog150 feeding the stock pump will work. I ran my low pressure FASS feeding my stock pump with my 190/75's about 4-5 years ago and fuel pressure was fine. I've been running my low pressure FASS feeding a fuelab high pressure pump for about 5 years now...fuel pressure stays at 60psi.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #10 of 110 Old 02-13-2014, 04:11 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Hmm Chris, someone else talking 190s eh?? Seems like that number came up in our conversation today. The key (IMO) to getting the power potential
from these trucks is ICP and therefore injection pressure as it just really helps with the atomization burn efficiency of the fuel. Tuning of course plays a role in this as well.
You are in a tough spot. I don't see your turbo (NOT BASHING HERE) being what you want for the power numbers you are after. If you said you wanted high 500s, I'd say that turbo is right, but for 650 or so hp, I'd say that in order to be clean, you're going to want some more air.
I would suggest if you want to keep your turbo to get 175/75s, WPE ported intake manifold, RR kit, AD150, AND dual HPOPs. That's right, I said it. Dual HPOPs with 175/75s... I'm sure that'll open a can of worms but that's ok. The extra oil may be a little over the top but I guarantee you that you'll get every drop of fuel possible from your injectors. Plus it'll allow you cut your injectors to something big like Charlie's 285/75s and be already to go.
I know it's overkill, but I'm a fan of the AD150 feeding a pump like an A1000 or Fuelab. I know I run an A1000, but if I were to do it over again, I'd get a 41402 Fuelab and run it at 70% output and call it a day. No need for a speed controller to keep the pump from running 100% all the time.
Thanks for the vote of confidence man However, I can not honestly say for sure whether my truck is a 600hp truck or not (hence why I removed the number from my signature). That was one run on one dyno and I never backed it up at the track. I'd rather not use my truck as a reference for making power. I believe it was definitely high 500s though.
william_ace and ODAWG714 like this.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
