More LiveWire TS problems - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 12 Old 02-13-2014, 05:13 AM Thread Starter
Brent Beeler's Avatar
SCT LiveWire TS isn't reading exhaust back pressure correctly
SCT Livewire ts problem 2007 6.0 - YouTube
Sent from AutoGuide.com App
Brent Beeler is offline
post #2 of 12 Old 02-13-2014, 05:38 AM
Gearhead2012's Avatar
Quoted: 2 Post(s)
Out of curiosity why did you start another thread about it? Not being rude... Just asking
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #3 of 12 Old 02-13-2014, 05:47 AM Thread Starter
I just feel that if A thread has been open for a day or two it loses a little steam, and also by naming it "more LiveWire TS problems" it might get noticed by someone having problems with theirs. I've been on this forum for a little while but I am by no means a pro ha ha. If anyone has any tips or suggestions on how to use the forum better I will gladly listen with open ears
post #4 of 12 Old 02-13-2014, 07:29 AM
Mine is the exact same. Call SCT and find out whats up with it as I am curious too.
Blue spring mod, Up pipe scoop removed, Sct livewire with QT tunes, muffler delete.
briand7878 is offline
post #5 of 12 Old 02-13-2014, 07:36 AM Thread Starter
I've called SCT and they said there is no problems that they know of with this however I submitted this video to them this morning via email so we'll see what happens hopefully an update or something to fix it
post #6 of 12 Old 02-13-2014, 07:40 AM
Good deal 're post your outcome so I can get the fix too.
post #7 of 12 Old 02-13-2014, 07:43 AM Thread Starter
Will do man
post #8 of 12 Old 02-13-2014, 08:00 AM
Quoted: 2 Post(s)
I know I have told them about this problem, so has charlie (peixino). I know the apple iPhone app/monitor Dashboss can read all the parameters properly... Way more than the crappy ol' TS can. I am not too impressed with the livewire ts, the screen sucks and it doesn't read as many Pid's as other options... Like edge. I would do Dashboss if I had a iPhone, if not I might do scan gauge, but I wouldn't buy a ts again.
peixinho likes this.
Under construction
Machining the 6.0:
post #9 of 12 Old 02-13-2014, 08:10 AM Thread Starter
I feel the same way I should have went with a CTS and the handheld SCT programmer this TS is the second one I've had it replaced already due to a no power up issue and to make it worse it had my stock tune file so I couldn't retrieve it had to deal with emailing back-and-forth with SCT to finally get a stock file back. Not to mention the problem I had with my pyrometer probe not working correctly got it replaced but still feel it's not reading the correct temp
post #10 of 12 Old 03-17-2014, 11:47 AM
NavPaul's Avatar
Just wanted to chime in here. I have had my Livewire TS since November and I have the same issues and more.
My exhaust back pressure is reading 47 psi with key on engine off.
units for boost are not correct, when I have it in PSI they are way off. Seems that when I put it in kPa they read what they should if it was in PSI.
My boost signal constantly maxes out causing me to have to keep resetting my max/mins.
Unfortunately the retailer I purchased it from (will withhold the name now because I have had no problems with them until now) will not take it back unless I take a 10% restock fee which I feel is BS because it was not working from the beginning. Also, when it was in service to replace a screen at SCT they said they would investigate and they did NOTHING.
Now the retailer I purchased it from keeps telling me that everyone else is having the same problems and the issue is on SCT. Has anyone had ANY resolution of these issues? This is garbage and very annoying to say the least, I would never purchase this garbage again.
NavPaul is offline
