Turbine Wheel Question - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 13 Old 02-12-2014, 07:55 PM Thread Starter
ZIKA's Avatar
While I have no personal data because i havnt driven my truck yet due to not having a rear axle in it but the more I read the more questions I have. I have a 68mm RCD Powermax with a BMW and the exhaust side is untouched. My worry is that it is not large enough to drive the compressor efficiently and I will have a hot smokey mess and wonder if the larger GT40 turbine would be a large improvement. If so... what would be involved in having it modified? What is the size difference? 4mm?...
Thanks!
06 F250 Reg Cab. ARP's, RCD Billet Powermax, Warren 190/100's, Areo A1000 Pump, Driven Diesel Reg Return, All AN Lines from the sump, Intake and Exhaust, 4" BDS Lift, Long Arm 4-Link, Dana 80 swap, 1480 u-joints, 4"/.108 driveline, Detroit Lockers (both axles), Warren Trans w/ Billet Shafts, Drive Flanges, 35"s, Traction Bars, Front Suspension Stops(For Tug-A-Truck), Rear Suspension Stops, Custom Hitch, Roll Pan, Lots of Drive Shafts, Axles, and Pinions.
ZIKA is offline
post #2 of 13 Old 02-12-2014, 08:04 PM
JGman141's Avatar
Thanks!
Basically that's the mtw stage 4, the larger turbine wheel will help a lot with improving the efficiency of the turbo. Is it really worth it? Depends on how you use the turbo.
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #3 of 13 Old 02-12-2014, 08:16 PM Thread Starter
ZIKA's Avatar
I use the truck as my dailey driver but sled pull pretty often. While I have my doubts that this will work but I will try to tow my other truck a couple times per month but northern Ohio is pretty flat which should help.
I have my Sterling almost band-aided back together so its driveable untill i get my Dana 80 all done so I should have some better idea on how it performs this weekend.
ZIKA is offline
post #4 of 13 Old 02-12-2014, 08:21 PM
JGman141's Avatar
I know barder can modify your turbine side and stuff a bigger wheel in to help.
ODAWG714 likes this.
JGman141 is offline
post #5 of 13 Old 02-12-2014, 08:26 PM Thread Starter
ZIKA's Avatar
What sucks is I dont want to dump a huge amount of money into this thing because eventually I will need to replace it with something with a 2.5 inlet. I tried to buy a stock powermax compressor to have it machined but it is not available seperate.
I should give them a call.
ZIKA is offline
post #6 of 13 Old 02-12-2014, 08:32 PM Thread Starter
ZIKA's Avatar
Will my existing compressor wheel screw onto the GT40 turbine shaft?
ZIKA is offline
post #7 of 13 Old 02-12-2014, 08:41 PM
JGman141's Avatar
I'm not sure,I bet James will be able to tell you if it would or not.
JGman141 is offline
post #8 of 13 Old 02-13-2014, 04:57 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
PM me, I have some ideas that might interest you.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #9 of 13 Old 02-13-2014, 07:18 AM
Nate, whatever happened to that other turbo idea you were talking about? You were looking for people with stage 2 turbos.
mikeproc is offline
post #10 of 13 Old 02-15-2014, 11:19 PM Thread Starter
ZIKA's Avatar
Anyone have any more insight on the turbine side?... Or even my compressor cover? Thanks.
ZIKA is offline
