Are these EBP readings normal? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-12-2014, 12:31 PM Thread Starter
Brent Beeler's Avatar
Are these EBP readings normal?-imageuploadedbyautoguide1392236996.331495.jpgAre these EBP readings normal?-imageuploadedbyautoguide1392237010.462948.jpg
07 6.0 with cat delete at an idle
Thanks in advance
Sent from AutoGuide.com App
Brent Beeler is offline
post #2 of 3 Old 02-12-2014, 01:18 PM
Gearhead2012's Avatar
Quoted: 2 Post(s)
No.. Sct screwed up on the PID for back pressure, you can't read it accurately with a live wire ts. We can only hope that a future update will resolve the issue. I'm hooking a mechanical gauge to mine, the stock sensor only goes to 38ish psi anyway.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #3 of 3 Old 02-12-2014, 02:43 PM Thread Starter
So I just got off the phone with SCT about this and they haven't heard of any issues nor are they working on any fixes for EBP on liveWire TS. However I have a snap on solis scanner that I am going to hook up to it to compare to. I will let you know the results if you want
