Traction Bars < or = 37's - Ford Powerstroke Diesel Forum
post #1 of 24 Old 02-10-2014, 10:43 AM Thread Starter
colonel angus's Avatar
Quoted: 2 Post(s)
I would prefer something that didn't reduce ground clearance.
What are you running or seen that works?
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #2 of 24 Old 02-10-2014, 10:47 AM
layson's Avatar
Quoted: 83 Post(s)
One Up Offroad but most don't want to spend that much. It is worth it in my opinion.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #3 of 24 Old 02-10-2014, 10:52 AM
Chatham036's Avatar
Quoted: 146 Post(s)
I use traction bars made by Flight Fabrications and really like them. They are a bit expensive but they are top notch quality with hiem joins on front and rear mounting locations.
Bryan (Tuscany) also runs them.. last time I heard from him, he was really pleased also.
if you are wanting something that does not interfere with ground clearance...
I know the owner of Darkhorse Diesel ( Josh aka DieselJosh ) has a guy at his shop who runs these on his 6.4l. I had a short conversation with Josh about them a couple months back and he did not have anything negative to say about the caltracs that I recall
hope this helps!!
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #4 of 24 Old 02-10-2014, 10:54 AM
layson's Avatar
Quoted: 83 Post(s)
I wish I still had that video on youtube of someone violently hopping running caltracs. They also make noise too... I would never put those on my truck.
They also do not do anything for you in reverse, say if you were backing up a trailer.
Quote of the Day:
layson is offline
post #5 of 24 Old 02-10-2014, 11:19 AM
Chatham036's Avatar
Quoted: 146 Post(s)
^^ there ya go then... I have no personal experience with them. I just know that if ground clearance is an issue.. the caltracs are an option to get around it.
here is my set up...
post #6 of 24 Old 02-10-2014, 11:25 AM Thread Starter
Quoted: 2 Post(s)
I assure you I would have those beaten into Spaghetti with the mild rocks i have to traverse getting to the Cabin.
I spoke with the Caltracs guys but didn't ask about potential noise from the aluminum front spring bushing.
That is almost enough to go with something else, pressing out bushings and pressing in others is a PIA I don't need.
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #7 of 24 Old 02-10-2014, 02:11 PM
ZWilson07's Avatar
How come no one seems to manufacture traction bars that actually sit over top of the rear springs vs under them?
Thats how they were setup when I had my ranger, from James Duff. I know it isn't the same power the diesels are putting down but I never see anyone using that design for the diesel trucks.
  • 1990 F250 RCLB 7.3 IDI 4x4 ZF5. 45,000 original miles and factory original as can be.
  • 2006 Dodge 3500 QCLB DRW 5.9 CR G56.
  • Vehicles for days!
Will never buy anything from IPR and Sinister! List still growing
ZWilson07 is offline
post #8 of 24 Old 02-10-2014, 02:29 PM
layson's Avatar
Quoted: 83 Post(s)
It would be very difficult to build a set of bars that worked properly above the leaf spring and the axle. People already hate how much a good set costs.
The traction bars I had on my truck did not hang down below the axle or the shock mounts. You just got to pay attention to where you drive and not get hung up on rocks or stumps. I have some friends that have some series wheeling rigs that have link arms that hang down just like traction bars and they don't have any issues. Then if you happen to bend or break one, you call up OUO and tell them what you did. I don't know if he would send you one for free but you just unbolt it and bolt in another one.
Quote of the Day:
layson is offline
post #9 of 24 Old 02-10-2014, 03:46 PM
Rough Country makes a traction bar that goes on top of the leafs, but it's in direct interference with the stops for the overload springs. I bought Pro Comp because they mounted at the axle centerline. If you're not lifted, the bars that mount to the blacks may not work for you.
Karl and his 2003 Souper Doody
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #10 of 24 Old 02-10-2014, 04:30 PM Thread Starter
Quoted: 2 Post(s)
6" Rear Blocks, so we're good there....
I'm pretty sure I'd give up the blocks for an integrated block and bar solution.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
