Traction bars/ Ladder bars - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 19 Old 02-10-2014, 09:06 AM Thread Starter
stroken828's Avatar
ok guys, i have a 6.0 250 lifted 16-18" with 46" military tires and this thing has the death wobbles around 50-70 MPH on the highway. i want to get rid of this or at least calm it down a bit. would yall suggest ladder bars? and should i get front and rear or just rear? i need some good suggestions and pics please.
thanks,
Jonny
stroken828 is offline
post #2 of 19 Old 02-10-2014, 09:26 AM
colonel angus's Avatar
Quoted: 2 Post(s)
That's one Tall order of expectations. I thought wanting a truck to run like stock with 37's was stretching it....
I'm going to bet it's more of a geometry issue than adding more steel to keep it from shaking once it gets in a rhythm since it does it at a particular speed.
Subscribed.
D
Karls03 likes this.
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #3 of 19 Old 02-10-2014, 09:47 AM Thread Starter
stroken828's Avatar
im not too worried about it running like stock obviously haha. just wanted to see if there were any ideas or suggestions on whether traction/ladders bars could help this wobble/ bouncing issue. and when i said 50-70 mph it doesnt only do it at those speeds. its just worse at higher speeds. you can still feel the bouncing at lower speeds.
post #4 of 19 Old 02-10-2014, 09:59 AM
layson's Avatar
Quoted: 82 Post(s)
Is it a leaf spring front end?
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #5 of 19 Old 02-10-2014, 10:04 AM
Another possibility could be the tires themselves. I have had 33s that vibrated the truck only to find out that one front tire was bad. You could try rotating them. I THINK those big tires can be balanced with shot being inserted into the tire before inflation.
Bottomline, I don't think those tires were intended to go any faster than 55.
huck2080 likes this.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #6 of 19 Old 02-10-2014, 10:06 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
or a ton of dyna beads
Karls03 likes this.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #7 of 19 Old 02-10-2014, 10:36 AM Thread Starter
stroken828's Avatar
have any of yall seen the "superduty hop" thread? posted by Nighthawk285. check this out. it sounds pretty solid to me. and as for the tires i will try having them rotated and see if that helps any. ill post results this weekend
post #8 of 19 Old 02-10-2014, 10:40 AM
Quoted: 2 Post(s)
I'd rotate them for you, if you were in Dallas.......... for $5000.00 and include balancing!!!
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #9 of 19 Old 02-10-2014, 10:40 AM
layson's Avatar
Quoted: 82 Post(s)
What type of lift is it? Is it a coil front end or a leaf spring front end?
You would definitely need traction bars but I don't think this isn't a traction bar issue and I doubt it is a frame strengthening issue...
Quote of the Day:
layson is offline
post #10 of 19 Old 02-10-2014, 10:42 AM Thread Starter
stroken828's Avatar
bahaha. im actually 3hrs from dallas but not looking to spend 5k on a tire rotation lol.
thanks for the option though.
