regulated return - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 11 Old 02-08-2014, 01:27 PM Thread Starter
regulated return
hey guys I have a question about my 6.0 fuel system. performance wise I don't think I need a regulated return system for my truck but I was wondering if you could plum up something where its not a dead head system. I want to install the blue spring kit and the 6.4 banjo bolts. Any info would help.
pinsonstang is offline
post #2 of 11 Old 02-08-2014, 03:28 PM
Check out the driven diesel setup, I think it's the best one out there. Plenty of guys build there own, lots of threads on it. I think it's important for healthy injectors as much as performance.
Casey
05' F350 cclb born 12-9-04
4 inch down pipe, 5 inch exhaust no cat
atlas 40 ficm tune, SCT tunes, Dashboss
ARP studs, egr delete ,driven diesel regulated return, WPE up pipes
Warren 175/75? ( wish I knew the nozzle size! )
MTW stage II turbo ( this week )
Six inch lift and 35-12.50-18 AT-II's
slvr bullet is offline
post #3 of 11 Old 02-08-2014, 08:34 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
There is no way to do a return off the back of the heads without a regulator. You have to have something there to keep the pressure up. The dead head system actually works pretty well. My fuel system is regulated before the heads like the stock setup but after the heads I essentially have a remote dead head with a second pressure gauge there. There is no difference in pressure in front of the heads or after them.
RIP Mitch
the Org crew
PGreenSVT is offline
post #4 of 11 Old 02-09-2014, 05:53 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 108 Post(s)
For stock trucks feeding the injectors clean, water free, air free fuel at the right pressure is the most important thing. Consider starting at the source of the fuel first for spending good money. A blue spring kit should cover you up top for now. Add a gauge to see what the whole system is doing.
JGman141 likes this.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #5 of 11 Old 02-11-2014, 03:44 PM Thread Starter
thanks for the info I'm going to put a fuel presure gauge on to see what I'm getting now then do the blue spring/banjo bolt stuff after. when taxes come in what size air dog would you'll suggest?
post #6 of 11 Old 02-12-2014, 07:47 AM
PGreenSVT's Avatar
Putting any Airdog on your truck would be the biggest mistake you could make in a fuel system mod. Just do a search. They just won't hold up on our trucks and Pure Flow has known it for years. Just ask any of us who went through multiple failures and problems.
ODAWG714 and 6 L chevy eater like this.
RIP Mitch
the Org crew
post #7 of 11 Old 02-12-2014, 08:13 AM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
I agree with Mitch here. The airdog2 has more failures than I can count. On the other hand I have an airdog 150 since 2010 and no issues to date. No clue why
But with all the new stuff out on the market with fuel lab and aeromotive I'd honestly try getting one of those. Truck source diesel has these I believe.
Also dale a sr ford tech on here has write ups and information for 6.7 fuel pumps that may benefit your needs
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #8 of 11 Old 02-12-2014, 08:33 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Originally Posted by ODAWG714 View Post
The airdog2 has more failures than I can count. On the other hand I have an airdog 150 since 2010 and no issues to date. No clue why...
I too have had an Airdog 150 on my truck for over two years without a single hick-up. I agree that the Airdog 2/165 is a POS and while Pure Flow has known it and not addressed it is unsatisfactory, but the Airdog 100/150s have been proven to be pretty much bullet proof in my experience.
ODAWG714 likes this.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #9 of 11 Old 02-12-2014, 10:23 AM
6 L chevy eater's Avatar
I have run air dog 2 & Fass lift pumps and had troubles with both. I now run an A1000 pump with fuel/water Sep filters and filter base from NAPA. Not a single prob with it. Holds psi extremely well also under WOT
2004 F250 ccsb
Skint Back Motorsports
Warren-HYBRIDS-- S400
FULL Billet Twisted Diesel Built Tranny
10.90@124 on fuel dammit
6 L chevy eater is offline
post #10 of 11 Old 02-12-2014, 08:06 PM
ZIKA's Avatar
This is what I did as well. An A1000 with napa bases and CAT filters. But to answer your question... I think that you can run a healthy stock fuel system and never have a problem with injectors up 175's and I heard even 190's but I personally had it work well with my old 175's. I ran the stock fuel system for 100k and never lost an injector and just think of the 1000's of trucks out there running it with no problems. If you have stock injectors... it is my "opinion" to keep fresh factory Motorcraft filters in it and run it.
06 F250 Reg Cab. ARP's, RCD Billet Powermax, Warren 190/100's, Areo A1000 Pump, Driven Diesel Reg Return, All AN Lines from the sump, Intake and Exhaust, 4" BDS Lift, Long Arm 4-Link, Dana 80 swap, 1480 u-joints, 4"/.108 driveline, Detroit Lockers (both axles), Warren Trans w/ Billet Shafts, Drive Flanges, 35"s, Traction Bars, Front Suspension Stops(For Tug-A-Truck), Rear Suspension Stops, Custom Hitch, Roll Pan, Lots of Drive Shafts, Axles, and Pinions.
ZIKA is offline
