Mishimoto radiator, transmission fitting??? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-06-2014, 08:32 PM Thread Starter
bootcamp's Avatar
Quoted: 3 Post(s)
Unhappy Mishimoto radiator, transmission fitting???
Got the new mishimoto radiator install, went to hook up the transmission lines and the fittings on the new radiator are different than what's on the factory radiator, trans oil cooler. The trans line went right in but the o-rings are squeezing out of one of drivers side connection. Can the o-rings be left off since these coolers are welded in place. Help me out please, working my but off to my beast back up and going.
Thanks,
Paul
USMC
05 F250 6" LIFT, Custom Fuel System, RR KIT, Fuel, TRANS, OIL, PYROMETER GAUGES, Fluid Damper, TSD & IDP Tunes, HellmaNs Sump, 4.10 Gears, ARP +625,Factory Gaskets,Apex ported manifold, MBRP EXHAUST , Atlas 40, Warren 175/75 injectors, 68mm Pmax w/ Batmowheel, BPD rad, BPD water pump, Sinister Y Pipe,Alradco Intercooler, O-Ring Heads and the list goes on.
bootcamp is offline
post #2 of 11 Old 02-07-2014, 06:12 AM
strokin6L's Avatar
Quoted: 3 Post(s)
Last I knew nothing was needed. Thought it should be a direct swap with nothing needed
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #3 of 11 Old 02-07-2014, 07:20 AM Thread Starter
bootcamp's Avatar
Quoted: 3 Post(s)
It is a direct swap, just don't like the orings squeezing out. The mishimoto radiator fittings aren't chamfered for the the orings and there web site said to put Teflon tape on the treads. So should be good to go. Will take them back off and Teflon the fittings. Since the cooler is welded into the radiator and not a separate piece like it is in the stock radiator should be ok with out the orings.
USMC
bootcamp is offline
post #4 of 11 Old 02-10-2014, 09:52 AM
Supporting Vendor
Quoted: 33 Post(s)
Hey guys,
For installation please remove the factory o-rings and use Teflon tape on the threads of the transmission fittings. This will ensure a proper, leak free seal.
Additionally we are revising this radiator design to be more user friendly and provide improved fitment for all transmission fittings.
Let me know if you have any questions!
Thanks
Mishimoto is offline
The Following 2 Users Say Thank You to Mishimoto For This Useful Post:
bootcamp (02-10-2014), Heavy_GD (02-25-2014)
post #5 of 11 Old 02-10-2014, 08:19 PM Thread Starter
bootcamp's Avatar
Quoted: 3 Post(s)
The orings are still there, but I did put Teflon on the threads, no leaks at this time and all is good. Hate to touch it just to remove the orings, my luck it would start leaking and not stop
USMC
bootcamp is offline
post #6 of 11 Old 02-11-2014, 07:20 AM
Supporting Vendor
Quoted: 33 Post(s)
That should work just fine!
post #7 of 11 Old 02-22-2014, 05:17 AM
1NastySS's Avatar
Quoted: 6 Post(s)
Originally Posted by Mishimoto View Post
Hey guys,
Thanks
I dont suppose this revision is available now,as Im lookiing to order one this week.Was also wondering if the radiator can be ordered in black like the intercoolers?Thanks
1NastySS is offline
post #8 of 11 Old 02-25-2014, 08:08 AM
Supporting Vendor
Quoted: 33 Post(s)
Unfortunately the revised product is not yet available. We do not currently have a timeline for the release but it will likely be a few months. The existing radiator still functions correctly, we just recognized a minor flaw and are working to mend the issue.
This radiator is currently only available in a polished aluminum finish. We have been receiving a substantial number of requests lately for black radiators. Thanks for the recommendation, we certainly take customer feedback seriously. I will check with our team and see if this is something we want to bring into our lineup.
post #9 of 11 Old 02-25-2014, 08:30 AM
Term3's Avatar
How many rows does the Mishimoto rad have?
Term3 is offline
post #10 of 11 Old 02-25-2014, 02:41 PM
1NastySS's Avatar
Quoted: 6 Post(s)
Thanks for replying,gonna order one this week.
1NastySS is offline
The Following User Says Thank You to 1NastySS For This Useful Post:
SHOOTER22250 (02-27-2014)
