Simple 6.0 build - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-04-2014, 06:43 PM Thread Starter
TxDiesel979's Avatar
Simple 6.0 build
I have been reading around the forums for a while now, but I cant seem to make up my mind, so any insight would be great! I've got an 05 6.0, fully reman motor with about 6k miles on it, ARP studs, egr delete, turbo back st8 pipe, coolant filter, Banks intake elbow and cold air intake, and its bored over just a tad. my goal is around 425-475hp, for the sake of the trany. As for future mods, I will be ordering the cts insight monitor, sct with custom tunes from gearhead most likely, and possibly some of the updates like the blue spring kit, dummy plugs, ect.. I rarely tow, and if I do, it would just be a couple fourwheelers for the deerlease. I mainly just want a fun/reliable dd. I'm kind of stuck on upgrading my turbo, I kind of like the idea of a non vgt, but I don't want to stray away from stock injectors. would this be possible with some good tuning? I like the actual exhaust sound over the turbo whistle, but then again I do like sounding like a jet cruising down the road. Also is a 58v FICM with atlas 40 or 80 a good idea? or no? Any suggestions on other mods would be great, I just want whats necessary.
TxDiesel979 is offline
post #2 of 9 Old 02-04-2014, 09:29 PM
jmeaby's Avatar
Quoted: 16 Post(s)
With a performance tune on sct you hit 425 all day long. Before you replace your parts like your ficm make sure they are failing don't waste money. Stage 1 turbo after that see if you still want more. Since your truck is studded already you don't have that to worry about buy your sct with custom tunes then buy your turbo.
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #3 of 9 Old 02-04-2014, 11:56 PM
6 L chevy eater's Avatar
If u buy a turbo buy a large vgt... 65-68mms range. That way you'll have the airflow if u do upgrade injectors. Because if u buy a smaller vgt now and do injectors later... ur gone need to buy a larger turbo later for the injector upgrade. Ain no need in buy-in two t urbos. Maybe someone elserl will chime in with ther opinion.
2004 F250 ccsb
Skint Back Motorsports
Warren-HYBRIDS-- S400
FULL Billet Twisted Diesel Built Tranny
10.90@124 on fuel dammit
6 L chevy eater is offline
post #4 of 9 Old 02-05-2014, 04:23 AM Thread Starter
Any recommendations on either the barder stage 1.5 or 2?
post #5 of 9 Old 02-05-2014, 06:19 AM
jmeaby's Avatar
Quoted: 16 Post(s)
I have heard great things about his stage 2 abd mtw stage 2. I haven't heard anything about the 1.5 do you do any towing
04 f250 cc sb.
jmeaby is offline
post #6 of 9 Old 02-05-2014, 06:35 AM Thread Starter
Not really, if I do it would just be a fourwheeler or two for our deerlease. I was looking on the mtw website and it goes from the stage 1 I think to the hybrid, but ive read somewhere that the hybrid is discontinued.
post #7 of 9 Old 02-05-2014, 09:31 AM
atleast get a stage 2
2004 F250 ccsb
post #8 of 9 Old 02-05-2014, 11:12 AM Thread Starter
Ok, I was wrong ha, they replaced the hybrid with the madmax. So has anyone heard anything about the madmax? If im not mistaken, its a tad bigger than the stage 2, and would either of these be compatible with stock injectors and proper tuning?
post #9 of 9 Old 02-06-2014, 08:13 AM
crashtest22's Avatar
Send a message via AIM to crashtest22
I am running whats in my sig and it all works really well together.
getting my MTW stage 2 upgraded to the latest from Adrian with a 10 blade because it was one of the first ones with the GT40 Compressor
James (crash)
2005 PSD Crew white short
4 inches ish lift with big tires
4 inch turbo back with no kitty
ARP with OEM Gaskets X2
Airaid Intake
MTW Stage 3 Turbo
Spearco Turbonetics IC
Andy Warren Comp Trans
Warren 155/30
BP EGR Cooler
Sinister Coolant Filter
NUC Bypass Filter
SRL+,SPD, Warren Tow, Race depending on mood
PMF Traction Bars
crashtest22 is offline
Tags
6.0 advice , performance mods , turbos , what's good?
