What Next? - Ford Powerstroke Diesel Forum
Old 10-20-2008, 10:20 PM
What Next?
I'm looking to add some more performance/fuel mileage to my truck. Whats something else I could do without having to add head studs yet? I thought about the FASS System. What about injectors? Which one should go first if i go that route of FASS and Injectors? I dont do any pulling of any kind either.
Old 10-20-2008, 11:18 PM
custom tunes, ITP regulated return. You would get FASS before injectors.
Old 10-20-2008, 11:22 PM
What is a ITP R/R?
Old 10-21-2008, 12:45 AM
ITP 6.0L Regulated Return Kit
Old 10-21-2008, 12:57 AM
Thanks for the link! Is this the samething as a FASS system? Could you tell any difference when you put yours on? What should I get in return, talking performance/mileage, after its installed?
Old 10-21-2008, 04:01 AM
Real Men Love Jesus! <><
a fass is a fuel/air seperator. I RR simply lets the air pass through the back of the heads and down to the tank again, to make sure that your injectors are only getting fuel and not air mixed in. Kinda the same thing, but totally different installs.
You should see a minor performance gain, maybe some mileage with the RR. It would really help if you go the injector route later on. I would do that versus the Fass personally.
Old 10-21-2008, 04:21 AM
The Lady Mod
Send a message via Yahoo to Granny
The regulated return can be a DIY install. Mine was done by npccpartsman (hubby) in the driveway in about 4 hours by himself. The ITP system is a very good product and Dennis is a great guy to deal with. The most important thing to do prior to the install is to lay all of your lines out and make yourself familiar with what you have and where they do and it will make the install much easier.
Old 10-23-2008, 03:04 AM
Here's the choices I have to add either a FASS, R/R, Banks Intercooler, ARP Head Studs or EGR Delete. What would you all choose if you had a choice? Is there not a R/R included in the FASS system? I see where you have both in your sig. Which one should be put on first if they both need put on? Thanks for help everyone!!
Old 10-23-2008, 05:01 AM
The Lady Mod
I already had the RR but it was not enough for my bigger injectors, that is the reason I added the FASS. If I had not needed the FASS for the injectors I would have not added it at this time. That is not to say that somwhere down the road I would not have, but I believe the RR would be a better mod to add if you are not going to be putting bigger injectors than a FASS. That is just my 2 cents. but I would do the EGR delete FIRST! That is the cause of many issues with the 6.0L
Old 10-23-2008, 05:13 AM
So, not to Hi Jack.....Granny, what would you put in in my case, RR or FASS?
