Egt gauge - Ford Powerstroke Diesel Forum
Old 10-20-2008, 06:51 PM
Egt gauge
Where do you guys tap in for your egt readings? i heard pre turbo is best, and i was wondering if i could do it in the driver side exhaust manifold where it goes up behind the motor?
Thanks in advance
Old 10-20-2008, 10:57 PM
check out dieselmanor.com for instructions, manifold is the best spot for it, who ever told post turbo is wrong!
Old 10-21-2008, 02:58 AM
Rob Rob is offline
if you read his post, he did say pre turbo, not post turbo...
Old 10-21-2008, 03:59 AM
Crawl under youre truck look up. You will see the exhaust manafold and a nice open area you can fit adrill in get the corasponding bit for the tap and drill the hole straight. Right in the manafold about 1.5" to 2" from up pipe flange.
Old 10-21-2008, 04:03 AM
Real Men Love Jesus! <><
yep, what he said.
Old 10-21-2008, 07:09 AM
Send a message via AIM to baseballguy
just make sure that you have a sharp bit. I was drilling for a good 5 minutes, getting no where with a dull drill bit. I even ran the battery out on my drill trying. Went to a neighbors house asked to borrow his, drilled right in like it was going through butter. =)
Old 10-21-2008, 12:01 PM
ok yeah thats where i had in mind...thanks
