Torque converter matching ? - Ford Powerstroke Diesel Forum
 22Likes
post #1 of 30 Old 02-03-2014, 01:09 PM Thread Starter
HP MACHINE's Avatar
Quoted: 105 Post(s)
Question Torque converter matching ?
Hey guys , can some of you chime in on the decision process for billet
TQ's . I want to upgrade to a triple disc / billet but don't understand the
decision process for stall speed .
I understand so far that stock is approx. 1800 rpm . After some reading
(I'm not sure if I'm rite ) will the stall "climb" higher with added hp / torque ?
If so , how ?
Also , let's say your shooting for 500 hp , would you go for a lower stall ?
I've seen ranges from 1200rpm and up .
Any help clearing these questions up and additional input would be
greatly appreciated .
(some of this comes from not fully understanding the function in the first
place and why the rpm should be moved up or down )
Thank you
HP MACHINE is offline
post #2 of 30 Old 02-03-2014, 01:12 PM Thread Starter
HP MACHINE's Avatar
Quoted: 105 Post(s)
Take that above series of questions based upon a daily driver not pure sled pulling or
towing huge all the time .
post #3 of 30 Old 02-03-2014, 04:01 PM
twoicebergs's Avatar
Quoted: 43 Post(s)
1600 or 1800 stall. Lower stalls are more designed for fuel economy and towing. The heaver duty units will have a shorter RPM slip range. Extra power shouldn't widen the slip jf designed for it, but the TC must be appropriate for the maximum power achieved. For typical performance you want it to be fully locked on its own design before max torque RPM, but not too low that you will be waiting for the turbo or having to select a lower gear.
HP MACHINE and Stiles like this.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 30 Old 02-03-2014, 04:19 PM
snafu!'s Avatar
While I was building my trans a 1600 stall was the rave, everyone recommend it. While it works well I would much rather have a 1800-2000 stall. I have a hard time building boost on launches, the truck starts pushing through the brakes at about 12psi.
The stall will raise some as HP is increased but no one was able to tell me how much. There are a lot of variables to account for.
I have found when changing tunes you have to get a good trans relearn or the TC will lock very aggressively. The converter will cause a drop in rpm and a slight turbo bark if the proper steps aren't taken when relearning.
HP MACHINE likes this.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #5 of 30 Old 02-03-2014, 04:28 PM
Quoted: 43 Post(s)
I was hoping you would give your 2 cents. This is a good example of matching for intended use. FWIW, I am still on the stock TC, and it will also push through if I do a boosted launch. Any racing application would want a higher stall.
Frank
Working for Toys
post #6 of 30 Old 02-03-2014, 05:09 PM
6 L chevy eater's Avatar
i have a suncoast convertor with a 2000 stall ..... when it locks on the track itll knock the change out of your pockets. it locks up nice and firm
2004 F250 ccsb
Skint Back Motorsports
Warren-HYBRIDS-- S400
FULL Billet Twisted Diesel Built Tranny
10.90@124 on fuel dammit
6 L chevy eater is offline
post #7 of 30 Old 02-03-2014, 05:41 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 97 Post(s)
Feedback Score: 3 reviews
I've heard to stay in the stock range. Another factor is the turbo. A big turbo needs to spool, if the TC is stalled too low the turbo lags. That's what I take out of my past conversations.
JGman141 and HP MACHINE like this.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #8 of 30 Old 02-03-2014, 07:17 PM
bondajb's Avatar
Just installed a P.I.. stock stall. . feels solid!!! I am happy with my choice.. I need to tweak a few shift points but over all I am very happy with my build..
Aaron 2005 f250 552/1040 45k miles
S&B. 4" mbrp, Arp's, Dual oil bypass. CCV fltr, Clnt fltr Mag trans pan 08 diff cover. 4.10's, 315's MotoMetal 951 & 5" lift.TGC trac bar, Bislstien Shocks & Dual stear stabilizer. B&W . Air Rides. Snows MPG Max. Edge Insight, fuel sens. DC Eng.185 alt. 58v ficm 6.4 Juger pump Fass sump
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
Flight Fab. Track bars
bondajb is offline
post #9 of 30 Old 02-04-2014, 06:38 AM Thread Starter
HP MACHINE's Avatar
Quoted: 105 Post(s)
Thanks guys , this very helpful .
post #10 of 30 Old 02-04-2014, 07:20 AM
Java's Avatar
I have a RCD converter with a 2000 stall and I really like it for driving in town. It feels like it's easier to build boost.
2011 6.7 F350 - Dads
2009 6.4 F350 - Brothers
2007 6.0 F350 - Mine
1997 7.3 F250 - Farm Truck
Java is offline
