Arp Torque Lube on everything else? - Ford Powerstroke Diesel Forum
 2Likes
  • 2 Post By JUGERNAUT
post #1 of 7 Old 02-03-2014, 08:47 AM Thread Starter
So I bought a 10 oz bottle to ARP torque lube to make sure I had enough to do my stud job. I also bought a bottle of permatex anti-seize. I'm wondering if anybody else is using the ARP lube on all the other bolts when putting everything else back together. A little curious due to it reducing torque values by about 18% on the studs compared to the previous lube they were using.
It would only make sense that it would reduce torque values for other bolts as well. At least that's my thoughts..
So use ARP or the permatex anti-seize?
FawlGuy is offline
post #2 of 7 Old 02-03-2014, 08:59 AM
wvrrcarknocker's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Send a message via Yahoo to wvrrcarknocker
ARP on the studs, anti seize on anything else you think needs it.
Originally Posted by ChiefRocka View Post
Great truck, but ugly and I felt like I was driving a penis down the road .....
wvrrcarknocker is offline
post #3 of 7 Old 02-04-2014, 08:37 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
I use ARP lube on TTY'S it'sa much better result in the torque process.
ZIKA and borsky4 like this.
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #4 of 7 Old 02-05-2014, 09:02 AM
I use the arp lube an all the internal bolts, I've used it on everything inside my engine so far as it goes back together. Main bolts, rod bolts, studs, rockers. Seems to work well.
Diesel Equipment service manager lead technician
jpott62 is offline
post #5 of 7 Old 02-05-2014, 05:46 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
My guess is the ARP lube is a graphite anti-seize. Used more for assembly than it is to keep fasteners from freezing up. I still use nickel anti-seize on exhaust parts/turbo clamps and save the ARP lube for the studs.
Hmmmm, I'm shortblocking a 6.4 right now. Maybe I'll try it
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #6 of 7 Old 02-05-2014, 06:00 PM
ZMANN's Avatar
Quoted: 1346 Post(s)
ARP | Official Website | ARP Ultra-Torque
We Miss you Ronnie
ZMANN is online now
post #7 of 7 Old 02-06-2014, 02:07 PM
ZIKA's Avatar
That is a hell of an idea. That last set of 90's will make a man out of you. I imagine is makes it easier than engine oil along with less binding on the bolt.
06 F250 Reg Cab. ARP's, RCD Billet Powermax, Warren 190/100's, Areo A1000 Pump, Driven Diesel Reg Return, All AN Lines from the sump, Intake and Exhaust, 4" BDS Lift, Long Arm 4-Link, Dana 80 swap, 1480 u-joints, 4"/.108 driveline, Detroit Lockers (both axles), Warren Trans w/ Billet Shafts, Drive Flanges, 35"s, Traction Bars, Front Suspension Stops(For Tug-A-Truck), Rear Suspension Stops, Custom Hitch, Roll Pan, Lots of Drive Shafts, Axles, and Pinions.
ZIKA is offline
