Launching ??
I will be going to the track next wednesday and I have a few questions...
1. Do i launch in 4wd? I thought that the 4wd is only good up to a certain speed? 2. I have heard to launch at or around 10psi? Correct? Any help would help. Thanks! |
don't watch your boost.. just bring it up to around 2,000 rpms for your 6.0 and let her eat.
Mess with tire pressures and varying rpm by 1-200 rpms since you have larger tires. Do you have anything to keep the axle in place? If not be careful, you can break sh!t real fast on oversized tires! |
Not that I know of. I bought the truck 2 weeks ago, so I am not sure of exactally whats on it.
I dont plan on making too many runs next wednesday, I just want to see what it can do. I am towing up my buddies 04 mach 1 that should easily dip into the 12's. So we shall see... Any other advise on launching? 4wd? or 2wd? |
With my dodges I would launch in 4wd and shift to 2wd around 45mph...it worked pretty well to help keep spinning the tires down..
with these trucks it shifts out of 4 wheel..
do what marty said and bring it up to about 2000 rpm..with 37s they should hook pretty good. if he jumps around then lower your rpm to like 17/1800 after the run just switch it to 2 wheel. i have brought my truck to 108 mph in 4wheel. from what i was told it switches itself out of 4wheel at a certain speed. just have fun and play with the truck a little bit. dont go crazy trying to launch it, practice on the street to get a feel for it. just switch to 4wheel and bring the Rs up a little bit and then switch over, you will feel it pull real good. let us know how you make out |
