Is it safe to upgrade my injectors - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-30-2014, 05:55 PM Thread Starter
Send a message via Skype™ to bwmtnbiker
I am in dire need of fixing a few things with my truck. My MPG has consistantly dropped in the last year. It has gone from 15-16 down to 11.5mpg. All calculations have been done by hand and my speedo is calibrated within 2-3mph.
I have been seeing a P0272 (Cyl 4 contribution balance low) code for quite sometime and I feel that this is a result of the injector. The truck is on its original injectors with 327,145 current miles. I know they are worn out and tired.
I know my FICM is starting to get weak as some mornings when its pretty cold (18-30F) it has dropped below 45 volts.
My plan is to send my FICM to FICMRepair.com and have it fixed along with the Atlas 40 or 80 tune. I also want to replace my injectors. My biggest questions are, Can I have Jesse refurbish the current injectors I have and make them larger or should I try and get new/a lower mile set? Also, will I be able to run slightly bigger injectors without causing my head gaskets to puke? I will do gaskets in the near future I just don't have the money for all of it now.
I need to do something soon because I know its only a matter of time before one component gives out. What direction should I start in. Ultimate goals for later on are bigger sticks and a MTW turbo (shooting for 550hp).
I just don't know what the best course of action is at this point because there are so many things that need to be done.
-Brian
2003 F-250 6.0L - Lariat King Ranch
-300k+ miles and still strong
Current Mods
-6.5" Pro-Comp lift
-Edge CTS
-SCT X3 (Tuned by Vivian
-4" Turbo Back Silverline Exhaust, 5"tip
-Blue Spring Mod
-Sinister Coolant Filter
-Oil Cooler
-Sinister EGR Delete
-OEM Cab Lights
Wants/Soon
-ARP Studs
-MTW Stage 1 or Hybrid
-6.4 Banjo Bolts?
bwmtnbiker is offline
post #2 of 5 Old 01-30-2014, 06:02 PM
wvrrcarknocker's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Send a message via Yahoo to wvrrcarknocker
Given your situation, I think i'd take care of the FICM, head gaskets, then injectors, in that order. If you feel your #4 is an issue, then I might just replace it, but honestly I think your head gaskets are a bigger issue than bigger injectors. I'd want a perfectly healthy stock motor before I started looking for more power, and my goals are in the same area as yours (500-550HP)
Originally Posted by ChiefRocka View Post
Great truck, but ugly and I felt like I was driving a penis down the road .....
wvrrcarknocker is offline
post #3 of 5 Old 01-30-2014, 06:06 PM Thread Starter
I am definitly going to take care of the FICM first because its showing signs of weakness and that could be the biggest cause at the moment. Saving up a little more for headgaskets is probably the smartest idea. I just wanted to get some opinions.
-Brian
Current Mods
-6.5" Pro-Comp lift
-Edge CTS
-Blue Spring Mod
-Oil Cooler
-OEM Cab Lights
Wants/Soon
-ARP Studs
-6.4 Banjo Bolts?
post #4 of 5 Old 01-30-2014, 06:29 PM
COONASS
WHAT HAPPENED's Avatar
I would call JSJ Extreme 4X4 ( https://www.facebook.com/pages/JSJ-E...17850018258652 ) for the HG and install unless you are going to do it on your own....
They are a great price...
2005 CCLB FX4
ARP, EGR Delete, 5 inch TB, SCT Livewire, Sinister Coolant filtration, ECL-1, PHP TUNES
Federal Ownership Respectfully Declined
WHAT HAPPENED is offline
post #5 of 5 Old 01-30-2014, 06:39 PM Thread Starter
Ill end up doing it myself to save costs on labor. I can definitely handle it. I jsut worked up a rough estimate that I will need $2351 in just parts not including heads.
-Brian
Current Mods
-6.5" Pro-Comp lift
-Edge CTS
-Blue Spring Mod
-Oil Cooler
-OEM Cab Lights
Wants/Soon
-ARP Studs
-6.4 Banjo Bolts?
