Injectors- OEM, Alliant, and Diapco? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 18 Old 01-30-2014, 03:00 PM Thread Starter
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
From what I've read, Warren uses OEM remans to make bigger injectors. What about River City Diesel (RCD), do they also use OEM remans for there bigger injectors? Same question about Elite Diesel, do they use OEM or a aftermarket company like Alliant or Dipaco to make bigger injectors?
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
The Following User Says Thank You to Lilpooh For This Useful Post:
rowekmr (05-22-2014)
post #2 of 18 Old 01-30-2014, 04:04 PM
5fifty's Avatar
IIRC my new 155/30's were made from Alliants. I bought them around February of last year.
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
post #3 of 18 Old 01-30-2014, 04:08 PM
ZMANN's Avatar
Quoted: 1661 Post(s)
Warren uses your old injectors or will sell you Alliant
the warranty will go from 6 months for your used injectors to a year with the Alliants
atleast for some of their units
then they also state they will use OEM new from Ford for some of the units but We all know new is not an option ????
We build your injectors from new OEM ford injectors,
We Miss you Ronnie
ZMANN is offline
post #4 of 18 Old 01-30-2014, 04:54 PM Thread Starter
Powerstroke Techie
Lilpooh's Avatar
Just makes me wonder is Alliant and Dipaco are just as good as OEM remans if the aftermarket injector builders (RCD/JW/EDE) are using them for bigger injectors.
Here is a little link from Diapco (DTech).
http://www.dtechproducts.com/Product...-6-0L-Injector
Lilpooh is offline
post #5 of 18 Old 01-30-2014, 05:58 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
UpTime Parts/PurePower Injectors is a division of Navistar for OEM injectors. Alliant is a source supplier as well. The question is who puts them in the Motorcraft box? I doubt they use a different reman company. The real question is who is the supplier for the parts that both of these and the other 2(?) remanufacturers use.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #6 of 18 Old 01-31-2014, 04:29 AM
HP MACHINE's Avatar
Quoted: 151 Post(s)
I noticed on the Dtech site ( and some others ) they list two different injectors for
03-04 and 05 -07 . What's the difference ?
Now I'm really confused about my truck . It's an 04' built in march of 2004 which seems
closer to the 05' model . It still uses the older HPOP design but the ICP is on the pass.
valve cover .
Any thoughts regarding injector series choice ?
HP MACHINE is offline
post #7 of 18 Old 01-31-2014, 05:31 AM
information regurgitator
NYC F-350's Avatar
Quoted: 51 Post(s)
The only differences I can find are the introduction of the DLC (9/29/2003) and a small change to the injector clevis ("mid-year" 2003 change).
I think the biggest difference as far as "fit" is concerned is the injector connector retaining clip orientation change, it went from a 9 o'clock position to a 12 o'clock position on all injectors after 9/29/2003.
Please
You could save the life of a sick child
NYC F-350 is offline
post #8 of 18 Old 01-31-2014, 08:37 AM
Dipacos dtech injectors are remanufactured by flight systems. I work for a diesel fuel injection shop. We get injectors from both places. I'm guessing most of the parts come from redat. They make a lot of replacement injector parts. Unless of course they are getting parts from siemens who originally made the injectors.
Diesel Equipment service manager lead technician
jpott62 is offline
post #9 of 18 Old 01-31-2014, 10:32 AM
Quoted: 48 Post(s)
OEM only on 6.0's IMO
Alliant's 7.3 injectors are fine, but their 6.0 injectors are way too hit or miss for my taste
drunk on diesel is offline
post #10 of 18 Old 01-31-2014, 11:41 AM Thread Starter
Powerstroke Techie
Lilpooh's Avatar
With reported hit/miss issues of non-OEM injectors, I wonder if there is a QC issues of the parts.
Maybe that's one of the reasons the non-OEM injectors are cheaper.
Lilpooh is offline
