68mm vgt's sucking in filter minder - Ford Powerstroke Diesel Forum
post #1 of 27 Old 01-30-2014, 04:37 AM Thread Starter
strokin6L's Avatar
Quoted: 4 Post(s)
How many of you guys running a 68mm vgt(KC, MTW, Barder, RCD) know whether or not if you're sucking in the filter minder? I know I am. I have to constantly push the button to reset it. The filter is 100% clean and I even run a pre filter. These 68 vgts really suck some air and makes me think that they need more of it. Makes me think that the normal aftermarket intakes like AFE, Banks, S&B, Volant etc just don't flow enough air for these large vgt's. Curious to know what you guys with the 68 vgt have noticed. Matt at CED has a custom intake and No Limit is just to release a custom one. The No Limit is 5" from the turbo all the way to a 5" inlet AFE filter. I hope to have the No Limit CAI on the truck in a couple months when I get it out of storage.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #2 of 27 Old 01-30-2014, 04:43 AM
JGman141's Avatar
Originally Posted by strokin6L View Post
How many of you guys running a 68mm vgt(KC, MTW, Barder, RCD) know whether or not if you're sucking in the filter minder? I know I am. I have to constantly push the button to reset it. The filter is 100% clean and I even run a pretty filter. These 68 vgts really suck some air and makes me think that they need more of it. Makes me think that the normal aftermarket intakes like AFE, Banks, S&B, Volant etc just don't flow enough air for these large vgt's. Curious to know what you guys with the 68 vgt have noticed. Matt at CED has a custom intake and No Limit is just to release a custom one. The No Limit is 5" from the turbo all the way to a 5" inlet AFE filter. I hope to have the No Limit CAI on the truck in a couple months when I get it out of storage.
I do all the time, I just unplugged it.
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #3 of 27 Old 01-30-2014, 04:59 AM Thread Starter
strokin6L's Avatar
Quoted: 4 Post(s)
I think a larger CAI with a larger inlet filter would really make a difference! More available air for the turbo, cooler temps and a little better throttle response are said to be had.
post #4 of 27 Old 01-30-2014, 05:04 AM
JGman141's Avatar
Might be able to put an intake for the s400 turbo on it and the could help a lot.
JGman141 is offline
post #5 of 27 Old 01-30-2014, 05:16 AM Thread Starter
strokin6L's Avatar
Quoted: 4 Post(s)
Here's what the No Limit CAI looks like
post #6 of 27 Old 01-30-2014, 05:31 AM
peixinho's Avatar
Quoted: 217 Post(s)
My filter minder is broken... so i can't chime in on that aspect. But i can say that I dyno'd the difference and it did not make that big of a difference.
I 100% pulled out the filter and blocked off the hot engine air so it was sucking 60 degree air from right outside. It did not make much of a difference on the dyno. But... that was one test one time on one truck with one dyno. I am going to do a little more testing before posting the dyno graphs
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #7 of 27 Old 01-30-2014, 05:42 AM Thread Starter
strokin6L's Avatar
Quoted: 4 Post(s)
Thanks for the input charlie! There should be some results on the No Limit soon. Garrett(Ptsuperd) will be running run soon with his RCD 68 vgt for some feedback.
post #8 of 27 Old 01-30-2014, 05:47 AM Thread Starter
strokin6L's Avatar
Quoted: 4 Post(s)
I know Greg from MPD went from a S&B to one of Matt's custom CAI and noticed a big difference with his 366 non vgt.
post #9 of 27 Old 01-30-2014, 05:52 AM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
Never had that issue Chris, I was running the AFE stage 2
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #10 of 27 Old 01-30-2014, 06:02 AM Thread Starter
strokin6L's Avatar
Quoted: 4 Post(s)
I'm running the AFE stage 2 also oliver and mine is sucking the minder in.
