performance intake manifold - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 14 Old 01-28-2014, 06:36 PM Thread Starter
I have found the brands cfm, bd diesel, sinister, and s&b. I believe these on a dodge they call an intake horn. Is the stock 6.0 intake 90 restrictive? I'm wanting to make my engine breath easier and faster.
04f-350 is offline
post #2 of 14 Old 01-28-2014, 06:54 PM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
The elbow isn't the problem, and replacing it would do little, if anything.
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 14 Old 01-28-2014, 07:15 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Yep, the restriction is the intake manifold and ports of the heads. The aftermarket elbows are good for bling and drilled/tapped ports, but even then you can drill/tap the stock elbow for ports.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #4 of 14 Old 01-28-2014, 07:39 PM Thread Starter
So it is agreed that it is a waist of money?
04f-350 is offline
post #5 of 14 Old 01-28-2014, 07:48 PM
JGman141's Avatar
Yep it's a waste of money
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #6 of 14 Old 01-28-2014, 07:58 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
I've heard positive reviews on the no limit.
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #7 of 14 Old 01-28-2014, 09:08 PM
Java's Avatar
I'm running a no limit cac pipe and like it a lot. I did other mods at the same time so I'm not sure if it made a difference or not. But it looks really good.
ODAWG714 likes this.
2011 6.7 F350 - Dads
2009 6.4 F350 - Brothers
2007 6.0 F350 - Mine
1997 7.3 F250 - Farm Truck
Java is offline
post #8 of 14 Old 01-28-2014, 10:05 PM
Consider this: what's the point of a bigger CAC pipe or elbow if it's going into the same sized hole in the intake manifold? It's like putting a 750 Holley on top of your old cast iron intake manifold. Sure it looks cool, but it's not doing anything else.
I bought a used Banks technicooler with plumbing and elbow. Nope, didn't do squat. Since I don't tow much, I have no real data there. But daily driving, yeah, 500 bucks lighter is all I got out of it.
Karl and his 2003 Souper Doody
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #9 of 14 Old 01-28-2014, 11:31 PM
smoke=cool=little kid
So let me break down something for.most people who say the elbows.don't do much. Your mainly.correct. all the little s&b, cfm etc... style.that utilize the factory CAC cold pipe suck. Complete waste of.money. however the no limit is a great product because it flows the air in a less.restrictive manor, as being its not a sharp 90 degree bend. Where as the no limit is a swept 90 degree over a bigger span creating more velocity an proper unrestrictive flow. But that's just me. I don't work for no limit, I don't push their product, I don't make.commission, I just have great results with the no limit and would justify the money
2004 F250 CCSB 44
Typical mods and performance parts
SCjake is offline
The Following User Says Thank You to SCjake For This Useful Post:
Karls03 (01-28-2014)
post #10 of 14 Old 01-28-2014, 11:44 PM
No limit would have to be the exception for the simple fact that they clean up the bends and such. The Banks tubing looks just like the OEM, just larger diameter.
SCjake likes this.
Karls03 is offline
