Which MTW? - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 12 Old 01-28-2014, 05:04 PM Thread Starter
Which MTW?
Alright my mods are in my signature. I need a turbo that's gonna give me outstanding flow with great spool up (little to no lag), and some decent power when I want on a nice tune. I tow on occasion up to 18000 lbs and I don't want no problems drivin through the coquihala in BC. Right now with my 155/30 stock 03' charger my egt's are way out of check. Hitting 1300 pretty easily on a decent grade uphill. Need to get these egt's in check. Any suggestions ?
Thanks
Sent from AutoGuide.com App
corycicuto is offline
post #2 of 12 Old 01-28-2014, 05:06 PM Thread Starter
Custom tuned already by Matt at gearhead. Been waiting on the madmax but also read up on the stage 2. ?? Need some help.
post #3 of 12 Old 01-28-2014, 05:08 PM
6 L chevy eater's Avatar
There are several options available for turbos. Check them all out before u pull the trigger on one in particular.....
2004 F250 ccsb
Skint Back Motorsports
Warren-HYBRIDS-- S400
FULL Billet Twisted Diesel Built Tranny
10.90@124 on fuel dammit
6 L chevy eater is offline
post #4 of 12 Old 01-28-2014, 05:13 PM
jmeaby's Avatar
Quoted: 16 Post(s)
A bigger turbo will help but probably would give u extra lag but better uptop. Have you looked into a water/meth setup? Give u a little extra power and help lower those egts a lot of ppl say better mileage too. I'm looking at a stage one or 2 when I buy.
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #5 of 12 Old 01-28-2014, 05:24 PM
Dirty_Stroke's Avatar
The way my Stage 2 spools with 155's, I personally would spend the extra cash and skip the stage 1 and get a stage 2. It will also give you room to grow if you should decide to in the future. I haven't gotten a chance to tow with this charger yet, but I feel it's not going to be an issue at all. It lights off so fast off idle that I would be willing to bet you couldn't tell that it isn't a stock charger if you drove the truck and I didn't tell you. I credit a lot of the zero lag to Chris's tuning. He really brought the low end response out in this turbo and the top end is nothing short of awesome.
masterninja2357 likes this.
05 F250 FX4 Lariat, SCT Livewire, 155cc injectors, Gryphon FICM tuner, ARP studs, MTW Stage 2 Turbo, Riff Raff boots, Warren Built trans, PMF traction bars ,4 inch straight pipe, Sinister EGR delete, S&B CAI, N-fab bars, level kit, 5% limo tint, 35 Toyos and 20s, Recon smoked everything, Harley headlights, 5k HID's, Camlocker toolbox, lots more
Dirty_Stroke is offline
The Following User Says Thank You to Dirty_Stroke For This Useful Post:
masterninja2357 (01-29-2014)
post #6 of 12 Old 01-29-2014, 07:45 AM
colonel angus's Avatar
Quoted: 2 Post(s)
I had a MTW stage 2 before they were stage 2's with my 155/30s and it was awesome, you won't be disappointed with the spool and extra power. It would likely clean up 175/30's to in case you want to go bigger in the future.
Since it doesn't require a core charge why not try it and if you don't like it MTW will give you your money back to apply it towards a Mad Max.
Win Win Right there.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
The Following User Says Thank You to colonel angus For This Useful Post:
post #7 of 12 Old 01-29-2014, 08:22 AM
Chatham036's Avatar
Quoted: 136 Post(s)
D
^^^ x2
I am doing some testing with the MadMax with stock injectors. My truck struggles to hit 1300 egt even on a hard throttle run.
I am running the 140x SCT tune with the Herc FICM tune. On the stock charger with the billet wicked wheel, I could hit 1500 - 1600 egts
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #8 of 12 Old 01-29-2014, 11:38 AM
masterninja2357's Avatar
Quoted: 3 Post(s)
D
This is exactly the setup I'm wanting to go with. Stage 2 155/30s. Think you guys just helped push me off the "fence".
-Morgan-
LOOKING FOR ANOTHER 6.0!
masterninja2357 is offline
post #9 of 12 Old 01-29-2014, 05:14 PM
andyjman's Avatar
Quoted: 2 Post(s)
I'm running some 175/30's and a barder stage 2.5 with gear heads tunes, and believe it or not it spools just as fast if not faster than the stock setup before the upgrade. I noticed a huge drop in turbo lag and the throttle response is awesome.
05 F350 CC LB FX4 Lariat, ARP studs, Barder 2.5 turbo,warren 175/30 injectors, Odawg ported manifold, S&B cold air, sinister coolant filter, Twisted Stage III Trans, DPC Conv, Mishi Rad BPD water pump, EGR delete, MBRP turbo back exhaust no muffler or kitty, edge insight monitor, tunes from Matt @ geadheads, rancho rs9000xl adjustable shocks .
My House Has A Ford Problem!!!! lol
andyjman is offline
post #10 of 12 Old 01-29-2014, 05:56 PM Thread Starter
thanks for all the info. that sounds pretty good! if MTW will refund and put the money towards a madmax that would be awesome. anybody got info on the specs of the new stage 2 turbo?. billet wheel? single or double plane? and what are the measurements of the housing and etc. much appreciated thanks.
