Shocks/Ball Joints - Ford Powerstroke Diesel Forum
post #1 of 18 Old 01-28-2014, 04:35 PM Thread Starter
binx_19's Avatar
Shocks/Ball Joints
So it turns out I need to replace the shocks and ball joints on my truck, i am wondering what are some good choices to upgrade to for the shocks.
binx_19 is offline
post #2 of 18 Old 01-28-2014, 04:43 PM
I read for weeks on Rancho 9000 vs Bilstein 5100...
I decided on the adjustable Rancho 9000s and could not be happier. You can buy stock or lifted lengths and dial the ride in to whatever you like... 9 shocks in one! I notice even my turns are smoother and stops easier without drooping... Granted my stock shocks had 156K on em...
Many like the Bils also, but read they were a bit firm... I honestly think you can't go wrong with either!
Autoplicity had the ranchos for 165 shipped for the front pair when I bought a couple weeks ago...
Good luck!
I dread the ball joints, but know I need to do mine soon also...
TxOutlaw is offline
The Following User Says Thank You to TxOutlaw For This Useful Post:
binx_19 (01-28-2014)
post #3 of 18 Old 01-28-2014, 04:55 PM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
I have used bilsteins on three different trucks. I like em especially for their rust proof Nicole body. But as he said, both are decent. Bilstein 5100s are stiff but get a touch softer with use
MrOneEyedBoh is offline
The Following User Says Thank You to MrOneEyedBoh For This Useful Post:
post #4 of 18 Old 01-28-2014, 05:03 PM Thread Starter
binx_19's Avatar
next question, i am wanting to go up to 20" rims which means i will also make at least a 5" - 6" jump in overall wheel diameter, would i be best just to do a lift on the truck then?
binx_19 is offline
post #5 of 18 Old 01-28-2014, 05:49 PM
It's not so much rim size that dictates what height you need, it's the tire size.
The_Auto_Tech is offline
post #6 of 18 Old 01-28-2014, 06:14 PM Thread Starter
binx_19's Avatar
the overall diameter looks to be going from 31 inches to 34.5 inches with the combo i am looking into buying.
would be going from 245/75R17 to 275/65R20
binx_19 is offline
post #7 of 18 Old 01-28-2014, 09:09 PM
I would be more concerned about buying quality ball joints. Which one is easier to change when they turn out to not be up to the job?
Karl and his 2003 Souper Doody
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #8 of 18 Old 01-28-2014, 11:48 PM
john galt's Avatar
Quoted: 1215 Post(s)
I ran ranchos and upgaded recently to a bds lift with fox shock upgrade and honestly BOTH rode really well. the ranchos made for a surprisingly smooth ride especially for a leaf spring truck.
Over all I think I agree with Karl I would put more time into the ball joints than the shocks
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #9 of 18 Old 01-29-2014, 03:38 AM Thread Starter
binx_19's Avatar
I already decided to go with Moog ball joints which is why i am looking into suspension now. so if i am going to have it off the ground, i might as well get the blown shocks changed too.
binx_19 is offline
The Following User Says Thank You to binx_19 For This Useful Post:
Karls03 (01-29-2014)
post #10 of 18 Old 01-29-2014, 04:20 AM
sbluke55's Avatar
Quoted: 548 Post(s)
Garage
Just some info for you. When you replace you ball joints with knurled ones (it's the ones with ridges around the side) you have to run knurled replacements from then on. If you have smooth ones they are more of a precise fit. All I'm saying is pick wisely.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
The Following User Says Thank You to sbluke55 For This Useful Post:
