03 EGR cooler? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-28-2014, 03:36 PM Thread Starter
03 EGR cooler?
Okay i just bought an 03 6.0 and i know it has the round style egr cooler.
I already bought monitoring software (dashboss) and my temps seem to be in the clear. I also cleaned out the EGR valve and it looked pretty clean.
Some people i have talked to say the 03 is much more reliable than the 04+
and that if you monitor the temps you should be fine.
Others say that no matter what cooler you should go ahead and get the bulletproof or delete it.
So.... to delete/replace or keep the 03 style cooler is the question.
Thanks!
FordTech101 is offline
post #2 of 11 Old 01-29-2014, 06:59 PM
jmeaby's Avatar
Quoted: 16 Post(s)
Block it off it's much cheaper and works very well. You can hammer freeze plugs in to both ends of it. My brothers ruptured and he did this 10000 miles later not a single problem
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #3 of 11 Old 01-29-2014, 07:04 PM Thread Starter
yeah someone also mentioned just welding it shut instead of getting a delete kit.
Ill have to look into the freeze plugs. never heard of that.
post #4 of 11 Old 01-29-2014, 07:14 PM
jmeaby's Avatar
Quoted: 16 Post(s)
They need to be just a little bigger then the hole and hammer them in with a sledgehammer
04 f250 cc sb.
jmeaby is offline
post #5 of 11 Old 01-29-2014, 09:35 PM
jmeaby's Avatar
Quoted: 16 Post(s)
Welding is also a good option. I didn't have a welder so freeze plugs worked very well.
04 f250 cc sb.
jmeaby is offline
post #6 of 11 Old 01-30-2014, 08:40 PM
Stupidity pisses me off
sevenmalards's Avatar
Quoted: 9 Post(s)
I just sold my 99.5 F350 and picked up an '06 KR. Where would you weld up the EGR Cooler to block it off?
2006 F350 CREW CAB LONG BED KING RANCH
99.5 F350 Super Cab Long Bed, Dually.
SOLD
Originally Posted by SMKSTAX View Post
You are not right man, but i still think your funny as hell!
sevenmalards is offline
post #7 of 11 Old 01-30-2014, 08:56 PM
jmeaby's Avatar
Quoted: 16 Post(s)
for a 06 you need to take the up pipe off and cut out the scoop that is in there to direct exhaust into the egr. on 03-04 they didnt have to do that. second i would weld both ends shut. i used the freeze plugs but i think welding is a great solution. you do need to tear the engine down quite a bit to get to it.
04 f250 cc sb.
jmeaby is offline
post #8 of 11 Old 01-30-2014, 09:01 PM
Quoted: 9 Post(s)
Define quite a bit
SOLD
post #9 of 11 Old 01-31-2014, 09:28 AM
jmeaby's Avatar
Quoted: 16 Post(s)
Down to the oil cooler it's not a bad job if u take your time and go slow. Check YouTube for videos srmastertech or something like that has great videos
04 f250 cc sb.
jmeaby is offline
post #10 of 11 Old 01-31-2014, 07:04 PM Thread Starter
despite being cheap i was hoping i would have some input that the 03 cooler is fine lol darn.
Tags
03 egr cooler
