Cat delete help please - Ford Powerstroke Diesel Forum
post #1 of 15 Old 01-28-2014, 01:16 PM Thread Starter
Brent Beeler's Avatar
I have an 07 6.0 and I have a hollowed out catalytic converter I was contemplating on putting in first question is will I notice any performance gains? Second question i've heard of people running a piece of tubing through the center, is there any reason I should do this or is it the same as just putting it on hollowed out. Thanks
Sent from AutoGuide.com App
Brent Beeler is offline
post #2 of 15 Old 01-31-2014, 07:07 PM
Depending on emissions testing in your state, the best thing would be to put a free flowing 4" exhaust on the truck. It will keep EGT's down and let the truck be more efficient. Your not going to notice much with just the cat as the rest of your exhaust is still restricted. I put the 4" Diamond Eye on mine with no cat($250 for turbo back complete kit) and love it. I live in Iowa so there are no emissions testing. I believe there is a Diamond Eye kit that has a free flowing cat for another $100 but I cant gurantee it will pass smog tests.
2006 F250 Lariat Bulletproofed
2006 F350 XLT bulletproofed SOLD
1983 Mustang GT 410/C4 SOLD
MustangSmitty is offline
post #3 of 15 Old 01-31-2014, 08:00 PM
What exactly do you have currently? A stock system I presume? It should help out a little bit depending on how plugged your current cat is, but the real gain would be from a 4" turbo back exhaust with no cat.
kornfanjoe is offline
post #4 of 15 Old 02-01-2014, 11:10 AM Thread Starter
So I've installed an empty cat with a 4 inch piece of exhaust tubing through the center of it the rest of the exhaust is 4" turbo back MBRP stainless with no muffler. Love the way it sounds but I swear I've lost torque could be my imagination or did I really lose a little power?
post #5 of 15 Old 02-01-2014, 11:12 AM Thread Starter
Also I have an SCT LiveWire with custom tunes from innovative and an AFR stage 2 intake.
post #6 of 15 Old 02-01-2014, 11:41 AM
6.0newb!'s Avatar
Quoted: 14 Post(s)
how did you do this??
06 f-250 ECSB xlt fx4, MBRP 4" cool duals, AFE stage 2 intake, BPD water pump, BPD egr cooler, stc update, stand pipes, dummy plugs, blue spring, late 04 up pipe, wicked wheel 2, PMM coolant filter, Riff Raff ic boots, t6-5w40, Rotella elc, leveling kit with 350 blocks, Pro Comp pro runner shocks, full Powerstop z36 brakes, PHP ficm tuner, insight cts w/egt, SCT x3 with canned tunes...... for now
6.0newb! is offline
post #7 of 15 Old 02-01-2014, 12:09 PM Thread Starter
I set the cat up on a welding table and cut the center out of it (the cat part) Cut on the factory welds and installed a 4 inch piece of exhaust tubing welded one end to the pipe and then slid the cat part over the top of that and welded everything looks completely factoryCat delete help please-imageuploadedbyautoguide1391285199.837899.jpgCat delete help please-imageuploadedbyautoguide1391285217.343418.jpg
post #8 of 15 Old 02-01-2014, 12:12 PM
Any time you reduce backpressure(which you did, you are gonig to get a little low end torque loss) so no, its not in your head. The flip side is that at WOT the motor should make more power and breathe better.
So you do have 4" coming off the turbo?
post #9 of 15 Old 02-01-2014, 12:14 PM Thread Starter
That sucks, because I can sure feel a difference I wonder if tweaking the tune may help a little bit because I sure don't want to put the cat back on because the sound is incredible
post #10 of 15 Old 02-01-2014, 12:14 PM Thread Starter
I'll have to call innovative to see what they think I guess
