Extreme studs.com - Ford Powerstroke Diesel Forum
 15Likes
post #1 of 101 Old 01-26-2014, 01:27 PM Thread Starter
05f250harley's Avatar
Extreme studs.com
Has anyone heard of these studs. I read on some of the cummins forums and it seams like they like them. They said they are comparable with arp 625s. If they are then they are a lot cheaper.
05 Harley Davison Edition Arp head studs, SCT livewire TS, 03 turbo, PMM egr delete, PMM coolant filter, afe cai, blue spring, 6.4 banjo bolts, updated stc, standpipes and dummy plugs, 4" exhaust with no cat and no muffler
03 RCSB 205/100 warren injectors, BW s366, Lots of supporting mods to come
05f250harley is offline
post #2 of 101 Old 01-26-2014, 01:29 PM
peixinho's Avatar
Quoted: 238 Post(s)
interesting... I am in for this one
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #3 of 101 Old 01-26-2014, 01:30 PM Thread Starter
They also said they use h13 material to make them
post #4 of 101 Old 01-26-2014, 01:46 PM
rdunagan's Avatar
this is an area that I would hate to try out and see. why not stick with the companies that do testing on there stuff all the time like arp to make sure they have the best quality stuff out there. Cheaping out on this area of the motor to me just seems alittle crazy to me but some are willing to try
2009 Ford F-350 FX4 4x4, H&S 300HD, MBRP 5" DP back exhaust, S&B intake, sinister egr delete, 4" BDS lift with fox shocks, 20x12 fuel nutz, 37" toyos, Custom painted headlights by me
SOLD: 2006 Ford F-350 4x4 King Ranch,ARP Head Studs and all the works
rdunagan is offline
post #5 of 101 Old 01-26-2014, 02:34 PM
Java's Avatar
Mike from no limit just became a dealer for them, he says they are a reputable company.
2011 6.7 F350 - Dads
2009 6.4 F350 - Brothers
2007 6.0 F350 - Mine
1997 7.3 F250 - Farm Truck
Java is offline
post #6 of 101 Old 01-26-2014, 02:40 PM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
Should get interesting.
Who's gonna try it first?
MrOneEyedBoh is offline
post #7 of 101 Old 01-26-2014, 02:50 PM
information regurgitator
NYC F-350's Avatar
Quoted: 54 Post(s)
Think I am missing something..
The only place that has the "extreme studs" (according to their own website) is Diesel Auto Power and they are $575.00
Browns Diesel has ARP's for $450
wvrrcarknocker likes this.
Please
You could save the life of a sick child
NYC F-350 is offline
post #8 of 101 Old 01-26-2014, 03:17 PM Thread Starter
I read that they are comparable to the arp 625s if that is true then they are a lot cheaper. I was just curious about these studs.
post #9 of 101 Old 01-26-2014, 03:21 PM
peixinho's Avatar
Quoted: 238 Post(s)
Yes you did miss something... Price is not everything. Many people are looking for a better option out there. Standard ARPs don't seem to be holding up anymore in high HP trucks. Many Many People are finding out that there OEM head gaskets with proper machine work and standard ARP studs are not holding up anymore. Over time they start to leak again.
This might fill in the gaps. The tensile strength is different.
normal ARP = 220,000 $450
extreme studs 240,000 $575
A1 H11 = 240,000 $750 (out of business)
aged ARP = 250,000 $1300
So the real comparison that you should be doing is...
aged arp for $1300
or
extreme studs for $575
ZIKA likes this.
KC Turbos
peixinho is offline
The Following User Says Thank You to peixinho For This Useful Post:
wvrrcarknocker (01-26-2014)
post #10 of 101 Old 01-26-2014, 03:30 PM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1865 Post(s)
Feedback Score: 4 reviews
I always wonder with all these threads and high-hp uses......how much can the stock block take? Not the cylinders handling HP, and such, but the block where your stud threads into....at the same torque, higher tensile strength studs will hold the head to the block better than lower strength right? Because the higher strength stud has a much higher plastic range, so at the same torque, it's actually pulling harder on the block threads than the lower one (because the lower one will absorb some of it)......aaaaaaaaaggggggghhhhhhhh I'm having a hard time putting my thoughts into words here, and I may be overthinking this anyhow, but hopefully someone gets what I'm saying?
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, KC S2R Ball Bearing Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is offline
