egr blocker plate - Ford Powerstroke Diesel Forum
Old 10-13-2008, 05:54 AM
egr blocker plate
anybody running just a egr blocker plate(freeze plug) on an 05 or newer? elites site says that it recommends the full new up pipe becuz the newer trucks have the scoop? I have an 06 now. also has anyone installed the new pipe, and was it pain in the ***? thanks guys..
Old 10-14-2008, 10:57 AM
the newer trucks do have a scoop i have an 2006 i don't really know if a new up pipe without the scoop is going to make any noticeable difference i have an egr delete kit that removes the entire cooler assembly and reroutes the coolant and uses a plate to block the factory up pipe and to answer your other question is yes changing the up pipes without removing the cab is a pain in the *** hope this helps
Old 10-14-2008, 12:42 PM
for the new trucks elite sells the whole sneaky pipe. its not that bad of a job...small areas and a few things in the way.
if you are gonna do it right get rid of the whole cooler itself. makes life a lot better.
