BPD Water pump + fan stator removal = awesome - Ford Powerstroke Diesel Forum
 7Likes
post #1 of 64 Old 01-25-2014, 07:32 PM Thread Starter
I win....
cRaZy8's Avatar
Quoted: 46 Post(s)
Garage
Ive had the BPD water pump sitting on my bench in my shop for a couple weeks. Finally found some time today to install it. Also helped there was no snow on the roads. Ever since I bought my Wrangler, the truck has become driveway queen during crappy weather. I hate salt, and people cant drive!
Ive never removed the fan stator for anything before, so this was a first for me.
Thanks to Lilpooh for his water pump write up, and Tuscany for his words on the trans cooler lines. Both were a big help.
It really is a shame that it is completely hidden. Its a piece of quality machining. Love their products.
And wouldnt you know it, it started snowing when I was ready to leave. Just my luck.
It really is crazy how much more room you have in the engine bay when you ditch the stator. Glad to chuck that thing in the dumpster.
S362 68/.91
Irate SS T4
Holders 175/30
BPD FICM
BPD Cooler
BPD WP
ARP
Yukon Locker
4.30's
ODP St3 Manifold
NL CAI
Rudy's Intake elbow
PSP Coolant Tank
Mishimoto Rad. & IC pipes
EGR Del.
Edge CTS2
SCT X3
FICM Tune
Jugger Pump w/DIY RR
Fuel PSI Gauge
35x18's
Bilstein 2.5"
Trac. Bars
DC Power
Powerstops
USCG 50GT MMC
Yamaha Outboard Master Tech
cRaZy8 is offline
post #2 of 64 Old 01-25-2014, 07:41 PM
Gearhead2012's Avatar
Quoted: 2 Post(s)
Did you notice any difference in coolant temps or fan clutch engaugement? My guess would be no...ive spoken with a few others that have done that...id be very curious to see if theres any difference while towing. Im sure some engineer somewhere spent hours and hours designing that stator lol...then again the same could be said about the egr cooler too. Im sure theres no issues unloaded...espcially when its cold enough to snow out...but i wonder if that might cause the fan to engage more often when under a heavy load in the middle of summer at low vehicle speeds.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #3 of 64 Old 01-25-2014, 07:53 PM Thread Starter
I win....
cRaZy8's Avatar
Quoted: 46 Post(s)
Garage
See this thread:
Prepping for a 3000 mile round trip- did I get it all??
I will find out soon enough.
The boat I am towing down is 4000lbs, trailer is about 1000lbs, plus two guys in the truck, plus sh!t ton of fishing tackle. Probably 1000lbs of gear and extra tools parts etc.
And if nothing else, this setup will be tested this summer.
By April 15th, my truck pretty much stays hooked to a trailer towing boats all over.
I frequently tow my boat 100-500 mile round trip during the summer when the the fish are biting.
S362 68/.91
Irate SS T4
Holders 175/30
BPD FICM
BPD Cooler
BPD WP
ARP
Yukon Locker
4.30's
ODP St3 Manifold
NL CAI
Rudy's Intake elbow
PSP Coolant Tank
EGR Del.
Edge CTS2
SCT X3
FICM Tune
Fuel PSI Gauge
35x18's
Bilstein 2.5"
Trac. Bars
DC Power
Powerstops
USCG 50GT MMC
cRaZy8 is offline
post #4 of 64 Old 01-26-2014, 11:08 AM
04cr450's Avatar
My stator is off as well and have been in 100+ degree temps and could not see a difference in engine temps. I agree, taking that stator off is a wise thing to do for clearing up the engine bay.... Changing a belt is a breeze now
JUGERNAUT and huck2080 like this.
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #5 of 64 Old 01-26-2014, 04:13 PM
strokin6L's Avatar
Quoted: 3 Post(s)
I've had the BPD water pump for a couple years. Temps don't change. The only big thing with the BPD pump is its fins. The stock fins are plastic and can wear and break off. Other than that there is no other improvement.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #6 of 64 Old 01-26-2014, 05:44 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
All you guys who are ditching your stators send me the bolts that attach it to the engine! i'll put them to good use on trucks that are missing bolts. You can't get these unless you buy a new stator and it irrates the hell out of me.
I have seen a few now that eat up fan clutch wiring from a broken or missing stator. It's one piece, while it can be a nuisance, I wouldn't remove completely.
ZIKA and JUGERNAUT like this.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #7 of 64 Old 01-26-2014, 06:29 PM
Quoted: 2 Post(s)
^^^ of course the fan clutch wiring is less of an issue if you ditch the fan clutch and go to electric fans lol.
Under construction
Machining the 6.0:
post #8 of 64 Old 01-26-2014, 06:47 PM
strokin6L's Avatar
Quoted: 3 Post(s)
My fan stator has been removed or a very long time. Never had an issue with the wiring! What kind of issues can you have?
post #9 of 64 Old 01-26-2014, 07:58 PM
04cr450's Avatar
the fan can cut the wire... I know lol it happened to me. Luckily I was able to save it as it just cut the molex plug connector and not the harness part to the stator, i spliced in a new plug and was good to go. I repositioned the wire so this wont happen again.
bpd
Warren comp trans
04cr450 is offline
post #10 of 64 Old 01-26-2014, 09:19 PM
portcity_gt's Avatar
Quoted: 1267 Post(s)
Ive towed heavy with the stator out and I live in the muggy south, no issues with temp.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
