Programmer without engine modifications - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-25-2014, 04:04 PM Thread Starter
This topic has been beaten but I could not find a direct answer. I have a fairly new to me 06 F250 with 75,000 miles and I am curious about programmers. Before buying, I read all the horror stories about the 6.0 but it seems that alot of the problems were due to improper maintenance and the use of extreme engine programmers. While the truck does pull my 5th wheel well, I thought a programmer would improve the experience. In addition, I have read that programmers can improve MPG. Can I safely use an SCT programmer without "bulletproofing" the engine? I am an older guy and don't race or light up the tires anymore but I would like to improve the performance but not at the expense of costly upgrades or repairs. Any thoughts. Thank you
2006 F250 crewcab XLT FX4 EGR delete, Cat delete, Aero Turbine muffler, coolant filter, soft tonneau, 5th wheel hitch, SCT tunes, 305/70/17 Terra Grapplers
1995 Corvette convertible
2011 Palomino Sabre 32" 5th wheel
2008 Harley-Davidson Sportster 1200
2000 Cobia 220 walkaround w/ Yamaha 200 ox-66 fuel injection
orlandimal is offline
post #2 of 7 Old 01-25-2014, 04:06 PM
Quoted: 48 Post(s)
Yes, you will be fine
drunk on diesel is offline
post #3 of 7 Old 01-25-2014, 04:08 PM
JGman141's Avatar
You should be fine
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #4 of 7 Old 01-25-2014, 05:22 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
You would be like most of the 6.0 owners that just want that little bit extra. I ran my last truck for years with just a SCT and a few tunes with zero issues. Generally speaking, the heavier the load, the more stock the tune.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #5 of 7 Old 01-25-2014, 06:03 PM
JustinOOO9's Avatar
Quoted: 461 Post(s)
Garage
I think its a gamble and heres why:
I love my 6.0 and im on my 3rd one after some hard learning experiences and I would run stock programming while towing and like my tow+50hp tune for DD, and tried my 150hp tune and I never saw a mpg increase and im extreamly OCD about hand calculating.
tons of people run a programmer with 0 issues for like of the truck and then there are some that run into problems related and non-related.
change the fluids and use oem filters and don't run a race tune you should be fine in my opinion. but when you put a higher horsepower tune your running into risky territory.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake.
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #6 of 7 Old 01-26-2014, 05:33 AM Thread Starter
Thanks for the responses. Glad to hear that the tuner will not put additional stress on the engine and lead to problems. I used to tow my 5th wheel with a 08 Silverado 2500 z71 gas and I did not like the constant shifting and high RPM's, even here in flat Florida. Even worse was the 8 MPG.
post #7 of 7 Old 01-26-2014, 07:53 AM
Quoted: 46 Post(s)
Actually it will stress the engine, just not that much depending on tune. Shifting and RPM is more to deal with load. Most engines run better at higher RPM pulling a load, including the mighty 6.0, but diesels will always tow way better than most gassers.
Frank
Working for Toys
