here's a cheap way to get your FP up..
fuel pressure, with a strong tune on my truck, will drop to 10 psi and can't recover until i lift..i put on an ITP RR kit and it would still drop out...i got a really good deal on a brand new HFCM and changed it out, thinking my old one was weak..still the same..
figured i'll give 2 pumps a try...bigger supply lines won't hurt either..
made a cheesy bracket with some DP that i had laying around and mounted my old HFCM to it..
mouted this in the frame rail and ran some bigger hard line to the front and rear...a little hose for the terminations to the pump..
i figured a better pickup tube wouldn't hurt, so i dropped the tank and made a "bulkhead" out of more crap...the stock pickup location on my Excursion tank wasn't in a bad spot, just small..i mounted my new pickup right next to the stock one..
the lockring for the pickup plate didn't want to go on easily after sitting in the sun..a BF clamp worked great to spin it on..
ran a little hose from the top of the tank and jacked it back up...tied everything together in the rear..
as of now the stock system is still 100% intact so i started the truck..no problems so far..i hot wired the new rear pump to make sure it could pull through the new pickup and got fuel..
next thing to do was to disconnect the stock supply line from the front pump and tie in the second pump..hot wired it and no leaks...pressure was good..finished up the wiring using the factory pump for coil voltage to a relay for the second pump..
now for the road test...got out and under hard accelaration where i could previously kill the fuel pressure, i couldn't get it below 58 PSI...my RR is set at 62 now...i didn't expect it to work this well...i was just hoping to keep it above 40...i'm a happy mofo..my frankenfuel BS worked..
cool thing about this is if i have a problem, the stock supply lines are still intact and i can reconnect it to the front pump in less than 5 minutes...
this isn't for guys with AM injectors...i have stockers and just needed a little help..when i do go bigger, i have the lines/pickup in place so a real pump won't be hard to install...this is great for us guys with just a tuner...ask your friends who are putting in FASS systems for their old pump..you can get this done for about $100 in parts after you get the pump..
