MAG-HYTECH PAN my 2 - Ford Powerstroke Diesel Forum
post #1 of 23 Old 01-24-2014, 10:41 PM Thread Starter
mossyoak's Avatar
MAG-HYTECH PAN my 2
I hear alot of people saying don't waste your money on it. Well I disagree totally,I purchased one for my 5r110 and I can say that I am pleased with it. Not only do I have the piece of mind that it helps make the case it's self stronger, it also does keep the fluid cooler. Now the stronger quote I base this on the fact that the pan is so much thicker than the stock pan, I mean you can't argue with thicker is better. Now the temperature argument I hear is that it is not proven. Well in my case it is. I drive 45 miles one way to work and with the old pan, my temp would get up to around 165, now with the pan and the extra 8 quarts my temp only gets to 150-155. Now when it is 95 outside verses 80 I can tell a difference, so I'm sure my tranny can tell it too. So I'll take stronger and cooler anyday not to mention it does look good too!
all the bullet proof things done, cat antifreeze, stock sticks, powermax / batmowheel, Tony Wildman tunes.
mossyoak is offline
post #2 of 23 Old 01-25-2014, 11:27 AM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
I went the DeRale route $ 125 cheaper; it's not cast aluminum but it holds 7-8 quarts more fluid and I can use the 08 filter and yes it keeps the transmission cooler and it cools down quicker due to the larger surface area of the pan.
sent from my Samsung S4
Shawn
2007 F-350 King Ranch FX4 LB Tow Boss DRW
SCT LiveWire, Atlas 80, WPE tunes, Blue Spring, Holders 175/30 injectors, KC Turbos Stage 2, Magnaflow Dual Tip 5", AMSOIL BMK-21, PMM Coolant Filter, Zoodad MOD, CCV MOD, AFE Pro Dry S OER Filter, Final Charge ELC, 08 style mirrors, SAP Diesel DD Solenoid, Derale Transmission Pan, Mishi CAC Tube and Boots, High Idle Mod, more to come..,
Qholic is online now
post #3 of 23 Old 01-25-2014, 11:39 AM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 79 Post(s)
Feedback Score: 7 reviews
what about the 08 pan, i heard that was better..(than stock 03-07)?
God bless America, the Constitution and the Second Amendment.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
powerstrokeshellback is offline
post #4 of 23 Old 01-25-2014, 11:48 AM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
It is better only because you can put an. 08 filter in it; it does not add any extra fluid though.
Shawn
post #5 of 23 Old 01-25-2014, 12:20 PM
Gearhead2012's Avatar
Quoted: 2 Post(s)
I got the maghytec pan when I had andy warren build my trans. I was very pleased with the quality. I hadn't seen a derale pan in person so I couldn't compare the two.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #6 of 23 Old 01-25-2014, 06:53 PM
Quoted: 12 Post(s)
People say the late 08+ pan is better because the earlier pans just have a screen inside but the earlier trucks had an external filter. Is there any evidence that the internal filter of the later trucks does a better job than the external filter or did Ford simply make a change when they repackaged the front of the truck to accommodate all the clutter of the 6.4's engine bay?
David Frost
2005 F250 Harley 6.0 CCSB
Towerguy is offline
post #7 of 23 Old 01-25-2014, 08:29 PM
Pwraddr's Avatar
Quoted: 3 Post(s)
Mag hytec on my dually also, never gets hot towing 13k
Pwraddr is offline
post #8 of 23 Old 01-26-2014, 12:45 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
The 08+ filters all the fluid as it goes through the transmission, the external filter on the earlier trucks is a bypass filter so only some of the fluid that is picked up from the pan is getting filtered.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #9 of 23 Old 01-26-2014, 06:09 AM
Can you run an 08 filter with the mag pan? Or maybe get an 08 mag pan for your 6.0?
Casey
05' F350 cclb born 12-9-04
4 inch down pipe, 5 inch exhaust no cat
atlas 40 ficm tune, SCT tunes, Dashboss
ARP studs, egr delete ,driven diesel regulated return, WPE up pipes
Warren 175/75? ( wish I knew the nozzle size! )
MTW stage II turbo ( this week )
Six inch lift and 35-12.50-18 AT-II's
slvr bullet is offline
post #10 of 23 Old 01-26-2014, 06:25 AM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1739 Post(s)
Feedback Score: 4 reviews
Yep, you sure can get an 08 mag pan....the 5R110 was still used in 08 Don't know about the 08 filter with an -07 pan though
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, Stage 2 KC Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD 58V FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is offline
