Egr block off plates - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 38 Old 01-24-2014, 12:16 PM Thread Starter
I have an 06 250 and am looking to do the egr delete plates but can not find them anywhere. I have searched for a couple of days with no results. I would do the entire delete but im under warranty and dont have those skills. Where can i find a good set. I have seen one on ebay but it does not look llike the other ones ive seen.
Thanks.
briand7878 is offline
post #2 of 38 Old 01-24-2014, 12:37 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Here is the spool valve and block plate.
http://bit.ly/PlbN55
http://iprresearch.com/product.php?productid=96
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 38 Old 01-24-2014, 07:38 PM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
The thing that nighthawk posted goes on top of the engine into the intake manifold. It is used to replace the EGR VALVE what you are looking for is a plate that is inserted into the EGR cooler that prevents any exhaust from entering the EGR system from the source. I don't have a link but I would recommend that you have the end of the EGR cooler welded instead of capped off because some of those caps are made of very thin material and I think it is possible that they could under certain cercumstances burst and defeat their purpose while others don't get a good seal on the EGR cooler.
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
post #4 of 38 Old 01-24-2014, 07:41 PM Thread Starter
I have done a lot of research on the spool and it looks easy to install. Now i have to figure out where the block off plate goes. I know it goes in an up pipe but honelstly have no idea where that is. IT sure would help for me to know what the guts of this truck look like since i just bought it. My problem is its -10 outside...
post #5 of 38 Old 01-24-2014, 07:48 PM
Powerstroke Techie
Lilpooh's Avatar
Link to blocker plate is provided in my other post. Takes you to the IPR site.
The idea of the blocker plate is so you don't have to remove turbo or on some models, the intake. Just loosen the up-pipe to cooler connection and slide in plate, then re-clamp connection.
The spool plug goes in place of the EGR valve, remove valve and install plug. Leave valve connected electrically and tied to the side.
The plate is designed to prevent gases from entering the cooler and the plug is designed to stop coolant from entering the intake, should the EGR cooler were to fail.
I ran this set-up for 5 years with no issues. Made my own.
Lilpooh is offline
post #6 of 38 Old 01-24-2014, 07:51 PM
Powerstroke Techie
Lilpooh's Avatar
Here is good starting point, gives part location and sensors.
http://www.backglass.org/duncan/ps60_manual/
Lilpooh is offline
post #7 of 38 Old 01-24-2014, 07:52 PM Thread Starter
Cool thanks for the pics. That helps!!
post #8 of 38 Old 01-24-2014, 07:55 PM
Teachagmech's Avatar
Quoted: 398 Post(s)
Garage
Do you see any merit to building a cap to go over the valve itself? I've thought about this several times. If only there was an easy way to clean the scoop out of the up pipe
Sent from a phone that makes calls too!
Mike"Bustin' mine to feed yours"
The "Kerosene Queen"
2005 F-250 CCSB FX4 LARIAT 150K blue spring, coolant filter, DC Power alt. and
Teachagmech is offline
post #9 of 38 Old 01-24-2014, 08:00 PM
Powerstroke Techie
Lilpooh's Avatar
It's a tight fit, if you look closely at the valve or spool plug, it shoulders down at the end. IIRC, it was like .020" step down on the OD. Not much room, and you would have to make that sleeve seal both against the valve and intake.
Lilpooh is offline
post #10 of 38 Old 01-24-2014, 08:14 PM
Quoted: 398 Post(s)
Garage
Should have clarified. A cap for the valve when the plug is in place
