GoGo DD Solenoid - Ford Powerstroke Diesel Forum
post #1 of 25 Old 01-24-2014, 06:06 AM Thread Starter
07DIESEL6L's Avatar
GoGo DD Solenoid
Any first hand experience of benefits on this product? Have read on some other forums where people swear by them but trying to get some more information if this upgrade is truly worth the money, figured since I'm about to change tranny filter and fluid it would be the perfect time to do this upgrade as well if its going to provide any benefit
07DIESEL6L
Bulletproofed
RCD EGR Delete
Sinister Diesel Coolant Filtration Kit
Warren Diesel 175/Stock injectors
ARP Studs
H&S Cold Air Intake
Mishimoto Intercooler Piping Kit
5" MBRP Turbo back with 8" Tip
Stock Turbo with billet wheel
Innovative 58v Tuned FICM
Tuning by IDP
07DIESEL6L is offline
post #2 of 25 Old 01-24-2014, 06:14 AM
portcity_gt's Avatar
Quoted: 1188 Post(s)
I think the general consensus is going to be ......good luck getting one.
a epc solenoid can easily be modified to work in its place either by you or I think a couple members on here are doing them for people.
but to answer your question, if your solenoid is weak then yes it will fix the problem. If your trans has other issues it will just be a bandaid.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is online now
post #3 of 25 Old 01-24-2014, 06:24 AM Thread Starter
07DIESEL6L's Avatar
I haven't had any tranny problems yet, but just tore the motor down and did a bunch of upgrades so I'm just trying to prevent anything bad from happening at this point want to prolong replacing the tranny for as long as I can
07DIESEL6L
Bulletproofed
RCD EGR Delete
ARP Studs
H&S Cold Air Intake
Tuning by IDP
post #4 of 25 Old 01-24-2014, 07:41 AM
colonel angus's Avatar
Quoted: 2 Post(s)
I did 2, the 3-5 shift flare/Reverse shutter and the DD EPC version.
Ford 5R110 Transmission Direct Solenloid | MTS Diesel Truck Parts
Another thread and source on the subject....
G2shuck modified dd solenoid review
Both made a noticeable difference and bought me some time until the BTS 3500.00 hit.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #5 of 25 Old 01-24-2014, 07:49 AM
PGreenSVT's Avatar
Feedback Score: 3 reviews
You don't want anything from Gogo Diesel. Doug Gilbert is a lying thieving POS. An EPC solenoid is easy to modify or just leave it clocked as it will.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #6 of 25 Old 01-24-2014, 07:57 AM Thread Starter
07DIESEL6L's Avatar
Thanks for the info colonel, I'll check them out. GoGo was the one I saw the people talking about in the thread I was reading, not partial to any company.
07DIESEL6L
Bulletproofed
RCD EGR Delete
ARP Studs
H&S Cold Air Intake
Tuning by IDP
post #7 of 25 Old 01-24-2014, 08:22 AM
peixinho's Avatar
Quoted: 174 Post(s)
I know this is heresay but i will post it anyways.
I talked with a lot of respectable tranny guys and they said that this is not an "upgrade"... but only a band aide if you are having problems. I was told if I don't have a 3-5 shift flare then there is no need for it. It won't help anything. And if I already have a 3-5 shift flare then 90% of the time it is because the clutches are worn and starting to go out. It will help hide/band aide the problem but it is never a permanent solution.
When I bought my new Andy Warren tranny I asked to have upgraded solenoids and he did not recommend it.
Basically it is just a band aide to hold you over until you can afford a new tranny.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #8 of 25 Old 01-24-2014, 08:31 AM
tuckman's Avatar
I have two I could part ways with, bought them for my excursion and buddy's super duty. We never did use them. I sold the excursion and then his tranny blew up.
Sent from AutoGuide.com App
2005 Excursion Limited 6.0 4X4
PHP tuned Swamps 58v FICM
Edge Insight CS, with universal 0-100psi sensor for fuel pressure
SCT tunes by Quick Tricks and Gearhead
Sinister EGR Delete and Coolant filtration kit w/Cat EC-1
6.4 banjo bolts
Ford fuel pressure spring kit
High Idle Mod
ARP head studs
Magnaflow 4" turbo back w/muffler
Powermax turbo
Firestone Ride-Rite air bags
Retro Solutions 55w 4300k digital HID's
Clarion NX500 double din DVD/Nav
tuckman is offline
post #9 of 25 Old 01-24-2014, 09:40 AM
Term3's Avatar
These are new and unused?
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #10 of 25 Old 01-24-2014, 07:39 PM
strokin6L's Avatar
Quoted: 3 Post(s)
I talked to Eric at ID about the DD solenoid a while back and he said its a good thing to do. He said they use them in all their trannys and would recommend one. Doug uses a EPC solenoid. I have one and it helps. Been running one for a long time now....probably nearly 4 years. There are a bunch of shops that sell a modded DD solenoid. A modded DD solenoid helps deliver more fluid to the DD clutch pack faster. Personally I don't think it acts as just a bandaid.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
