Manual Transmission tunes? - Ford Powerstroke Diesel Forum
post #1 of 17 Old 01-23-2014, 10:21 AM Thread Starter
i have an 03 6.0 PSD. It has the ZF6 6-speed transmission. Just installed a 5" straight pipe. but that is it for mods. Im looking at buying a tuner and wondering which one would benefit me the most. My truck does not have head studs and I do not want to blow gaskets. I understand that its a risk to run a tune without them but would be okay to put a mild tune? if so, who should i go through, and what ype of tune. Just looking for a little bit more horsepower and better MPG's. any help would be greatly appreciated.
strokindavis is offline
post #2 of 17 Old 01-24-2014, 08:15 AM
I have an 06 (Manual Trans) without studs and have been running the FICM Atlas 40 tune from.
Power Hungry Performance - Feed your hunger for POWER!
Cuts the turbo lag significantly,
Adds a few more horses
MPG, don't expect much
I think it is pretty headbolt safe.
Jungleman is offline
post #3 of 17 Old 01-24-2014, 09:44 AM
Metal Mulisha's Avatar
You cant guarantee any tune is going to be safe for your stock head bolts but you can get a very mild tune that should be safe for a while. I ran a pretty hot tune for 20k miles before my stock gaskets went. Do you have an egr delete?
2006 F-250 Lariat
Super Cab short bed
20% tint
20" LED light bar
Diamond eye 5" straight pipe
River City Diesel EGR delete
ARP head studs w/ OEM gaskets
Blue spring
SCT X3 xtreme street
Edge Insight CTS
Mag Hytec diff cover
7 inch Icon lift
20x10 machinedFuel Hostage rims
37x13.50x20 Toyo Open Country M/T
Metal Mulisha is offline
post #4 of 17 Old 01-27-2014, 04:41 AM Thread Starter
metal mulisha.. heard the EGR cooler in the 03 was actually designed good and doesnt need to be deleted. i was thinking on going with SCT and they have the EGR shut off switch... Should i still delete? or will this shut off switch help.
post #5 of 17 Old 01-27-2014, 04:43 AM
JGman141's Avatar
I would delete it because it can still cause problems even if it's turned off
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #6 of 17 Old 01-27-2014, 04:46 AM Thread Starter
and jungleman.. the Atlas 40 is just your FICM that you send in for recalibration for $150 or so right?
post #7 of 17 Old 02-03-2014, 11:06 AM
I have an SCT with some tunes from what was DJs way back when...now Quicktricks.
I have run the tuner for the better part of about 50K miles with the engine all stock. I finally did have the truck bullet proofed a few months ago after the EGR cooler let go. The head gaskets looked like they were on the way out too, but had not yet gone.
Back to the topic...I have three tunes...a tow, a street, and the loony. The tow is a good tune...I do run it when I have the trailer on. It is more power, you will notice the differance.
The looney is fun, but I'm gonna tell you that I can't shift it fast enough. And it can be a handfull if either you aren't ready for it or the road is wet, snow, or ice. I don't let the wife drive it unless I put the tow tune on it.
As for the MPGs...well, don't get your hopes up too much. It will help some, but I didn't notice much improvement honestly...1-2 MAYBE...and that is if I baby it.
2005 F250 4x4 6.0L PSD, 6 Speed hand shaker
Dark Shadow Gray
SCT xCal2 with DJ's Tunes, MBRP Turbo-back Offroad exhaust...bye, bye kitty and muffler.
Finally studed, EGR deleted, blue spring, Zoodad and AFE CAI
Groundhawg is offline
post #8 of 17 Old 02-03-2014, 01:19 PM
That is the FICM tune only. You can get them to mail you the programer and do it yourself, or if you need a FICM repair you can have it done then. Just make sure you follow the directions they give you with it.
I have an EGR delete and an SCT tuner. I don't use the SCT to tune (just to turn off the EGR so the engine light isn't on) because I am afraid of HG failure, which may happen anyway.
Your head gaskets could fail without any tune, but the more tune and power you add the more chances of it happening (my opinion). I really only did the FICM atlas 40 tune to cut the turbo lag and maybe add some MPG. It does cut the lag. Don't expect much, if any, on the MPG gain.
post #9 of 17 Old 02-04-2014, 04:40 AM
Dont run a very big tune or you'll regret it. FICM tune or maybe a tow tune TOPS. Anything else will lift heads and push gaskets, and destroy your egr cooler. Its just the way she goes..
Stlavsa is offline
post #10 of 17 Old 02-04-2014, 11:04 AM Thread Starter
thanks guys i appreciate the input. all suggestions are needed when youre gettin ready to dump cash into your diesel. ill let you know what i go with and tell you how it works for me.
