The tribulations of 58v FICM and another thanks to Ed at FICM repair - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 14 Old 01-22-2014, 03:34 PM Thread Starter
Although I'm not a regular poster, I do read the forums regularly.
I have a rebuilt, 0-ringed, studded, motor with all the updates, etc. I'm the 2nd owner. I've been monitoring everything on the torque ap from Ian Hawkins and it's been helpful.
I was so used to seeing 48V FICM Main Power, clean starts, good mileage, that I started to neglect my normal monitoring of the FICM.
Over time, and as it got colder in the mid-west I started to notice a slightly rough idle on start and slightly worse mileage. It was a gradual reduction in performance and figured it was not an issue. In fact I figured it was just the cold.
Then the POLAR VORTEX came. It was -10 F that Monday morning on my way to work when the "thinkable" happened. The truck lost power just down the street from the house. Eventually it died. I parked it let it sit for a few minutes, and checked the codes on torque (611 and 282). Luckily, it started right back up and I drove it up the driveway and examined my readings in real time.
FICM Logic Power was 12.5ish. Main was down in the mid 30s. Yikes. I came back the next day and checked again with slightly worse results: Mid 20's on start, rough idle, etc.
I have new Interstates, and always leave a battery tender on it every day.
I knew it was the FICM and took it out when the weather warmed up. I also knew the original owner had a 58V mod, but I didn't know who did the work. After removal it was pretty obvious because it had their part number and company name on it. (It was a very reputable company in TN and that's all I'll say.)
I contacted this company and they told me it was done in 2011, and since I wasn't the original owner they would offer me 5% off their exchange price. It was only a 1 year warranty. Needless to say I passed and decided to send it to Ed based on the great reviews. I opted for the most premium package with the lifetime warranty.
I figured it would be a quick fix and I'd be back in business. Not the case.
Ed calls and after hours of work diagnosing, repairing, etc., when the unit was tested it wouldn't cut the mustard. He mentioned that many 58V unit are baked and black when they come in, but mine passed the "visual" inspection. Perplexed he spent even more time investigating. What started as a normal repair of a modified unit turned out to be hours of diagnosis to finally reveal the Logic and Power boards were still toast, but not black-burnt toast.
So now I start from scratch and out almost double what I expected. The FICM arrived yesterday and I got it on today. It fired right up in 20 F with a smooth idle that was familiar.
I took a snap of the FICM outputs just after start before the alternator comes on line.
FLP 11.5
FMP 50.0
FVP 11.5
V CM 11.3
(This was on 3 month old Interstates, kept on a charge, and before the alternator came on.)
After alternator contactor closed it read.
FLP 14.0
FMP 50.0
FVP 14.0
V CM 14.1
(Cranking the FMP was 49.5)
Works great. Problem solved.
The "B" side to the story is another well-known PS company had "flashed my FICM" with ATLAS 40 when the engine was rebuilt. It was on my invoice. Since this was my first 6.0 I had nothing else to compare it too? I was always happy with my great mileage and plenty of power. I drive like a grandpa so what do I know about the extra 100lb tq?
I'd explained to Ed the FICM had ATLAS and I wanted to maintain it. He sends an email stating I had the ARZ2AL11 tune instead. WTF? I promptly contacted PHP and the installer of the tune. My FICM must have been mixed up in the shuffle.
Based on Ed's reputation alone the installer regretted the situation and I've been "taken care" of.
My opinions on ATLAS 40? Worth the $150 for the mileage alone! I've never seen these kind of numbers with my city driving! I'll keep a log of my longer trips in the future. I'll never take advantage of the increased peak torque, but who knows?
Bottom line from the long story is:
I don't recommend 58V.
If they advertise they have less than 1% return on FICMs it's because the warranty period is too short to realize all of the eventual failures.
I recommend FICMrepair.com
I recommend ATLAS 40.
Thanks for reading.
HP MACHINE likes this.
cambo61 is offline
The Following User Says Thank You to cambo61 For This Useful Post:
ATV PRO 11 (01-23-2014)
post #2 of 14 Old 01-22-2014, 03:53 PM
npccpartsman's Avatar
Quoted: 5 Post(s)
Nice testimonial. Ed's customer service is absolutely top notch and on the same level as Ryan Casserly, Bulletproof Diesel, and Trucks Unlimited.
Glad he got you fixed up. I think you'll enjoy his product for a long time to come.
I Bleed Razorback Red
Ford Makes It, International Shakes It, Casserly Fuels It, KC Turbo Spools It, SCT Tunes It, and Trucks Unlimited keeps her Rockin the Road
npccpartsman is offline
post #3 of 14 Old 01-22-2014, 05:11 PM
HP MACHINE's Avatar
Quoted: 104 Post(s)
Bill at PHP was thrown the question by me ( about the value of the 58v ficm ) when he
was doing my rollback etc. He said that anytime he'd heard about one going down it
was disaster inside . Glad they got you fixed up .
There's nothing like a nice runnin' 6.0 in my mind !
HP MACHINE is offline
post #4 of 14 Old 01-23-2014, 01:45 PM
Glad you got fixed up! Been talking with Ed about my 58v modded OEM FCIM today... Looks like I am sending mine in as well... Thinking the Premium or Ultra with Atlas 40 as well. May do the trade in so I can avoid down time...
TxOutlaw is offline
post #5 of 14 Old 01-23-2014, 03:05 PM
turbotibbo's Avatar
What's the trade in??
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #6 of 14 Old 01-23-2014, 03:19 PM
From what I read on the site, for additional $50, he sends out the unit you want, then you send yours to him once you swap them out...
Maybe someone has done this?
TxOutlaw is offline
post #7 of 14 Old 01-23-2014, 04:20 PM
ATV PRO 11's Avatar
Ohhhh Snap. I've had code P0611 and P1378 for awhile. Both FICM related
Swamps 58V FICM.
Better cold start issues since PHP's tune but still the codes and start issues.
I'm thinking It may be a good time to send the FICM into Ed and see what's what.
I will say, this is a fantastic testimonial!!!!!
ATV RACING.......cause football, soccer, baseball, tennis and GOLF only require ONE BALL
Curtis
04 Excursion Ltd
6.0 Studded
EGR Delete
PHP Gryphon9
Swamps 58V FICM
AFE Stage 2 intake
4" Turbo back w/5" tip
Deaver springs front, Icon Dynamics rear 6" lift
Dual Fox w/resi's front, Fox w/resi's rear
Custom fit Bushwacker Flare's
4:88 gear, Detroit Rear
Front/Rear DVD w back up camera
1500W of Kicker power
42" Goodyear MTR winter
37" Yokohama Geolander summer
ATV PRO 11 is offline
post #8 of 14 Old 01-23-2014, 04:34 PM
I confirmed this with Ed, 50$ extra for trade in, plus a deposit until he receives your old ficm.
TxOutlaw is offline
post #9 of 14 Old 01-23-2014, 05:21 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
I also just started getting these codes. Ficm on my CTS never drops below 49.5.
Batteries are a week old AGM's and alternator is a 240 unit that runs 13.7-13.9 constantly.
Is a new FICM in order?
2005 F350 CCLB FX4
2005 F350 CCLB FX4
juniorssrollin is offline
post #10 of 14 Old 01-23-2014, 06:18 PM
ATV PRO 11's Avatar
2005 F350 CCLB FX4
My batteries are good, New alt getting 14.2 14.4 regular.
13.7 your close to needing a new one IMO (from what i've read on here)
49.5, again, from what i've read it's still good.
I get 50V on my Gryphon, but i've read they don't read above that for the 58V swamps I have. For me, IMHO, a new FICM is in order. FYI, i've replaced the relay at $80 here in Canada (code 1378 Voltage low, connection, relay, short, charging system)
Hope that helps ya
Curtis
04 Excursion Ltd
6.0 Studded
EGR Delete
PHP Gryphon9
Swamps 58V FICM
AFE Stage 2 intake
