Durability of stock Pistons and rods.. - Ford Powerstroke Diesel Forum
 7Likes
post #1 of 18 Old 01-20-2014, 02:18 PM Thread Starter
BigRedOne's Avatar
Quoted: 5 Post(s)
So with the planned build of the 6.0 super truck, I am planning on pushing out big numbers in terms of HP. My question is how well would the stock pistons and rods with all the related parts hold up under severe work before they explode? Anyone have pistons or rods break due to HP?
2005 F350 XL 6.0
ARP studs
EGR delete
5" turbo back straight pipe
AFE intake
BPD 58v FICM
03 turbo
Sinister Y pipes
SCT tuner
Edge insight cts
All upgraded OEM parts
BigRedOne is offline
post #2 of 18 Old 01-20-2014, 08:41 PM
Quoted: 364 Post(s)
Feedback Score: 5 reviews
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #3 of 18 Old 01-20-2014, 08:49 PM
03Cody's Avatar
A guy in a diesel power mag article has a work stock puller with a stock bottom end that dyno'd at like 750 hp and like 1200ft lbs. idk how often it's used or how it's used other than pulling but there's a start for ya lol.
-Cody-
03Cody is offline
post #4 of 18 Old 01-20-2014, 10:06 PM
ZWilson07's Avatar
What do you consider servere work lol?
Personally I don't think they would be having a very happy life in 600-700 rwhp under medium work.
Depending on your definition of "severe" id probably keep it around 500 rwhp if it was me but again that is largely dependent on your definition and what you plan on doing.
  • 1990 F250 RCLB 7.3 IDI 4x4 ZF5. 45,000 original miles and factory original as can be.
  • 2006 Dodge 3500 QCLB DRW 5.9 CR G56.
  • Vehicles for days!
Will never buy anything from IPR and Sinister! List still growing
ZWilson07 is offline
post #5 of 18 Old 01-20-2014, 11:22 PM
turbotibbo's Avatar
Subscribing , any one blow there. Bottom end up ? Pics ?
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #6 of 18 Old 01-21-2014, 03:42 AM
Chatham036's Avatar
Quoted: 136 Post(s)
Mine is just north of 500 rwhp and I can say that putting this much power down is plenty to keep me happy.
But I work for a diesel shop... Therefore I will be pushing the hp rating up higher anyway
ODAWG714 likes this.
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #7 of 18 Old 01-21-2014, 03:51 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Stock pistons and Rods are good for about 600-650ish
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #8 of 18 Old 01-21-2014, 04:14 AM Thread Starter
BigRedOne's Avatar
Quoted: 5 Post(s)
I will be listing a mod list later on this evening in a build thread.. Now mind you i wont be WOT 100% of the time but I do like to have fun and pull and drag. I want to be worry free if I am pushing 50 PSI of boost through race heads and not having to worry about my pistons going through those said heads.. 600-650 would be in the drive around town red light to red light application. With that being said, I am just curious on their strength only because I have on found a few sets of actual after market race rods but more pistons. Maybe you guys could point me in a direction of a supplier if you know any good ones.
2005 F350 XL 6.0
ARP studs
EGR delete
AFE intake
BPD 58v FICM
03 turbo
Sinister Y pipes
SCT tuner
Edge insight cts
post #9 of 18 Old 01-21-2014, 09:58 AM
stonepusher's Avatar
FWIW mine has lasted through multiple 800+ dyno runs, a handful of 800+ 1/4 runs and still going strong. The only thing that has let go has been the head gaskets. Best numbers are 865hp 1450tq dyno and a 10.93@123. Stock bottom ends are very stout
ZIKA and ODAWG714 like this.
2005 F-250 6.0 BTS 4r100,285/150's, TSD sump, TSD fuel system, TSD tuned, Barder stage 3, and some other goodies.THANKS TO TRUCK SOURCE DIESEL!!
11.72@114 Fuel
11.00@126 One stage of gogo juice
stonepusher is offline
post #10 of 18 Old 01-21-2014, 10:03 AM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
I would say if your planning on abusing the truck and if the truck has several thousands of miles I would do a engine build just for the added insurance. Fwiw Mr stone pusher abuses his and his lower end is holding up fine
stonepusher likes this.
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
