Installing glow shift fuel pressure gauge? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-20-2014, 12:46 PM Thread Starter
nibesdiesel's Avatar
From my understanding I need the adapter bolt to the fuel bowl and then screw in the sensor that comes with it then it's just wiring from there correct?
nibesdiesel is offline
post #2 of 7 Old 01-20-2014, 01:44 PM
Yep. You will need an adapter. Sending units are 1/8NPT and test port is 12X1.5. Some sending unit are smaller than others.....
GlowShift Ford 6.0L Diesel Fuel Pressure Adapter
Sensor Relocation Hose Kit
I used the relocation kit to make the installation cleaner. I had to replace the adapter O-ring. The one from Glowshift was junk.
Use the pressure test port on your upper fuel filter housing.
tartfun is offline
post #3 of 7 Old 01-20-2014, 01:49 PM Thread Starter
Well my 07 took a crap so I'm bought an 03 motor bulletproof and I'm kind broke could I get the braided line from anywhere or do I have to order it?
post #4 of 7 Old 01-20-2014, 02:36 PM
You will need the adapter no matter what. After that you can use any 1/8NPT hose/line you want or just put the sender right on the fuel bowl.
You might have some harness issues with that 03 engine in a 07. Several sensors got moved from 03 to 07. ICP etc...
tartfun is offline
post #5 of 7 Old 01-20-2014, 02:52 PM Thread Starter
I have the 03 harness do to the sensors in a different areas
post #6 of 7 Old 01-20-2014, 02:58 PM
Bashby80's Avatar
I used a grease gun hose from a D&B Supply. works and cheap.
2001 dodge 2500 cummins 178k miles *sold*
2005 ford f250 6.0 Powerstroke Lariat FX4
20x10 Eagle Alloys (2.5 pro comp lift to be installed)
69k miles at purchase
Edge Insight CTS (w/ pyro)
Blue Spring w/ gauge on steering colmn
SCT X3 w/ Looney Tunes
5" dual miter stacks straight piped
Sinister coolant filter
High idle mod AUX4/Back up cam AUX3
Bashby80 is offline
post #7 of 7 Old 01-20-2014, 04:54 PM
Quoted: 8 Post(s)
I got the fitting from Glowshift, but when I screwed it into the test port the whole set up was still really loose. Like the previous poster I too swapped the O ring, but I still wasn't comfortable with how it sealed. I added some Teflon tape to the threads. I filled the fuel bowl back up, but haven't started the truck so I don't know if it will leak yet.
2005 Excursion Lariat 4x4
Mishimoto coolant filter, RCD EGR delete, '03 turbo w/ single plane billet compressor wheel, Edge CTS w/ EGT probe, 5" Rough County suspension, Hellwig 32mm sway bar, 35x12.50 Toyo M/T, 20x12 Fuel Renegade D263 wheels
Originally Posted by F450Harley View Post
I really believe these trucks have adaptive behaviors to your driving habits. Your truck reflects you.
If you think your truck might let you down…………..it WILL.
6literdiesel is offline
