VGT Tunability - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-19-2014, 09:10 PM Thread Starter
wickednnk's Avatar
VGT Tunability
Just got a question and I'm not real sure if it would be a benefit or a absolute no no.
I was messing around with my scan tool an noticed I could open or fully close the vanes in the turbo. Well I fully closed them and took it for a short drive. I closely watched the boost and EGTs and I noticed that the truck built boost much sooner in the RPMS and maintained a lower EGT under part throttle.
Well what I'm wondering is if anyone has ever wrote a tune to only operate the vanes as a wastegate to manage pressure and leave it fully closed during acceleration and fully open under deceleration.
Just want to know how this would function and if it would be an absolute negative or if it would be a bonus. Lower EGTs made me smile a little not gonna lie.
2004 F-250 PSD. IDP custom tuning, 4" MBRP turbo back exhaust, AFE stage 2 intake, ARP studs, DIY 175cc sticks, Modded VG Turbo, high idle mod, zoodad, MKM EGR delete kit, Port Matched Intake Manifold, Bulletproof Diesel FICM, Bulletproof Diesel Aluminum Radiator, Coolant Filter.
wickednnk is offline
post #2 of 4 Old 01-19-2014, 09:23 PM
turbotibbo's Avatar
Subscribed
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #3 of 4 Old 01-19-2014, 09:34 PM
madpowerstroke's Avatar
Oh boy, I will try to answer the beat I can. The problem with keeping vanes closed and operating as a waste gate functionis that the turbo will actually be acting like a non vgt turbo. A small non vgt and would over speed the compressor. The truck would not have any top end, just bottom and maybe so mid. The turbo would sort of act like the vanes being stuck in one position, but have a waste gate when let off. There is a reason why the ecm controls the vgt solenoid with all the info it gets like backpressure, load, flow and such. You are really asking for trouble and won't work very well at all, you will actually have a bad running truck. Let the ecm do want it is suppose to on the vgt, I have seen too many people think they are smarter then the ecm to only mess up their trucks. Hope this made sense.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #4 of 4 Old 01-19-2014, 09:43 PM Thread Starter
wickednnk's Avatar
Thank you for the response. I was kinda figuring that it would take away with it being as small as it is just wandered because of how much it added to the low end makes me kinda want to tune it to close more in the low end and then return to normal in the high RPM and flow.
