Promaxx heads - Ford Powerstroke Diesel Forum
post #1 of 12 Old 01-19-2014, 07:33 PM Thread Starter
BigRedOne's Avatar
Quoted: 5 Post(s)
Promaxx heads
Being new to the forum I have no posts except in the intro page, if you don't recognize me, thats why.. Anyway I have blueprints for a serious build for my 05 6.0. I am looking at the Promaxx heads. Anyone have any thoughts on these? I am not even going to mess with my stock heads. They have 220K miles on them so they did there fair share of work.. I am looking to get extreme HP and am worried if these will take the beating.
2005 F350 XL 6.0
ARP studs
EGR delete
5" turbo back straight pipe
AFE intake
BPD 58v FICM
03 turbo
Sinister Y pipes
SCT tuner
Edge insight cts
All upgraded OEM parts
BigRedOne is offline
post #2 of 12 Old 01-20-2014, 03:29 AM
kdogg85's Avatar
Are those the $10000 heads people have been talking about?
Are you wanting a full competition truck or a money pit(what I'm building)?
And what hp number are you shooting for?
David
05 f250 ( double your pleasure ) underway
'10 f250 ccsb 4x4, project super mom 366/515 compounds, 200hp sticks, and all the other goodies
Most importantly, the car seat mod
kdogg85 is offline
post #3 of 12 Old 01-20-2014, 10:12 AM Thread Starter
BigRedOne's Avatar
Quoted: 5 Post(s)
They are $1600 for the set. Not just remaned stock ones either.. Built thicker in the prone areas of the head. I am doing this build just to have it.. I may pull a few times at the fair and peel down the strip a few times to kill GM and dodge but other than that she will be my daily driver.. I just want that balls to the back of the seat feeling and you cant move when WOT.. Im a guy.. And for HP range I am not to sure yet.. Im blueprinting it from scratch so I am hoping to be in the 600 rwhp all set and done..
2005 F350 XL 6.0
ARP studs
EGR delete
AFE intake
BPD 58v FICM
03 turbo
Sinister Y pipes
SCT tuner
Edge insight cts
post #4 of 12 Old 01-20-2014, 10:18 AM
kdogg85's Avatar
Unless you just really don't want your old heads, that doesn't sound bad for the price.
600hp is pretty easy to come by these days. The easiest way is going to be a big vgt and 190-205cc size injectors. An old saying was that 205's were the limit for what the hpop can handle. You definitely won't need heads if you checked yours and they were ok to use.
David
kdogg85 is offline
post #5 of 12 Old 01-20-2014, 10:28 AM Thread Starter
BigRedOne's Avatar
Quoted: 5 Post(s)
The 600HP range was a pure guestimate. I can hot rod a chevy 350 gas job and know exactly what I am going to get for HP but being new to diesels I am clueless.. I will list a part list when its compiled. I am afraid that even if my factory heads are ok, they have 220K+ miles on them and if I'm pushing major boost and heat they will fail. I am building a truly bullet proof engine for serious HP. For all I know, the set up I am planning will give me 1000 HP. I just don't know
2005 F350 XL 6.0
ARP studs
EGR delete
AFE intake
BPD 58v FICM
03 turbo
Sinister Y pipes
SCT tuner
Edge insight cts
post #6 of 12 Old 01-20-2014, 03:22 PM
Quoted: 5 Post(s)
Feedback Score: 3 reviews
Promaxx heads were deemed to be chinese garbage.....
Promaxx heads
Good luck if you get a set.
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
post #7 of 12 Old 01-20-2014, 03:51 PM
strokin6L's Avatar
Quoted: 4 Post(s)
if anything....I would get RCD's port n polished heads if you looking for heads that really flow and are up to the task for the power level you're wanting.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
The Following User Says Thank You to strokin6L For This Useful Post:
BigRedOne (01-20-2014)
post #8 of 12 Old 01-20-2014, 04:03 PM
strokin6L's Avatar
Quoted: 4 Post(s)
Or these that will out flow anything out there Ford Diesel Heads
You will need deep pockets for those!
post #9 of 12 Old 01-20-2014, 04:05 PM Thread Starter
BigRedOne's Avatar
Quoted: 5 Post(s)
Thanks guys for the tips and warnings.. this is why this forum is great. Saves members thousands in mistakes!!
2005 F350 XL 6.0
ARP studs
EGR delete
AFE intake
BPD 58v FICM
03 turbo
Sinister Y pipes
SCT tuner
Edge insight cts
post #10 of 12 Old 01-20-2014, 04:09 PM Thread Starter
BigRedOne's Avatar
Quoted: 5 Post(s)
Those are some serious heads.. but for $9000 thats pretty much 2/3 my build budget.
2005 F350 XL 6.0
ARP studs
EGR delete
AFE intake
BPD 58v FICM
03 turbo
Sinister Y pipes
SCT tuner
Edge insight cts
