mbrp 5" TB install
im gonna be installing a mbrp 5" turbo back this weekend and wondering if you guys have any tips for me to make it a little easier, i heard the down pipe can give you problems.
cut it at the bottom of the firewall. then pry the tab on the top of the DP off the turbo and it'll almost fall right out. other than that it's pretty straight forward. if your are doing it by yourself, put the top half of new the DP up from the bottom and wedge it in there so you can jump up top and grab it then put the band clamp on there snug enough so it wont fall of but not so tight to where you can't turn it by hand from underneath. jump back under the truck and slide the second half up on there and put the clamp on it. DON'T tighten anything till you have the mid pipe in the right spot. the snug the DP up. hope that helps.
Have a buddy, wife, child, girlfriend, neighbor kid, SOMEONE......... help with the downpipe. I did mine by myself and it was a PAIN!!! Other than that, just take your time, everything should go right into place.
Note - I did a 4", the 5" may be a little trickier. |
i dint want to cut my DP cause i want to be able to put my stock exhaust back on to pass inspection, is it possible to not cut the DP
ehhh not really, but you can still pass inspection with a big exhaust that doesnt really change anything. now a chip or big sticks will fail you in emissions lol
the only way to pull it out w/o cutting it is to take out the trans x member. i think it would be easier for you to just cut the dp out, then get 3.5"-4" couplers for the cat to go back in when you need to.
allright thanks for the help ill let you know how it went and how it sounds cant f in wait
put it on in 2 hrs thats with a few drinks in between, installation was pretty straight forward, The truck now sounds Sick Nasty when you get into it I love it.
