AirDog 100
Just wanted to get people's opinions on this, I've been mulling this over as well as some other things. I'm not going to do anything with the EGR right now, the tune that I have on my Livewire shuts it off anyways. And Studs I'm going to have to wait till I get up to the dealer again. But I've talked to the guys at pureflow tech, and they gave me all the info I wanted on the Airdog, and given that it won't void my warranty, it increases HP/torque and improves MPG, and is realtively lowcost right now,its pretty worthwhile in my mind, just want some opinions first though.
Thanks. -BG06. |
it will work for you no problem but you can't use just that by itself, you will still need to run the stock pump that is on the framerail. the only way to eliminate that is to also by the Raptor pump and run them both. the raptor takes the place of the stock pump and the AD goes between that and the tank. true you will most likely see a little bit better fuel economy just b/c it's filtering the air and water out of the system and fine filtering the fuel.
Hey every little bit that I can get, I'll take.
-BG06. |
