Turbo upgrade - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 26 Old 01-18-2014, 05:35 PM Thread Starter
RY86's Avatar
Turbo upgrade
Hey guys had a question about a powermaxx turbo. I have my 6.0L torn apart doing a bullet proof diesel EGR cooler an Oil cooler. Well all this is apart I happened to notice that my stock turbo has a ton of side to side play. So much that it has touched the side of the housing. Its time for a new one. I was thinking of replacing it with an OEM turbo until I started to read a few things online about a Garrett Powermaxx. I did have a few questions that I hope someone could answer. I have heard that with a powermaxx there is alot of turbo lag. My powerstroke is completely stock. Stock tune, stock head bolts. Are there tunes out there that are specifically for a Powermaxx turbo? Like I said my truck is entirly stock. EGR, stock headbolts, cat and muffler are all still inplace. I use my truck as my daily driver and it has served me well. I do tow with it acouple times a month but nothing to insane. Mainly I tow a fully aluminum Trition trailer with 4 atvs onboard. If it helps its a 2006 with 98,000 miles.
Ryan
2006 Powerstroke 6.0
Blue spring mod
CAT EC-1
Coolant filter
Garrett Powermax turbo
Tuned by gearhead performance
MBRP 4" tubro back exhaust 5" rolled tip
4" ICON suspension lift
35" toyo MT's
BMF Novakanes
RY86 is offline
post #2 of 26 Old 01-18-2014, 05:40 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
subscribed
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 26 Old 01-18-2014, 08:27 PM
Quoted: 5 Post(s)
Feedback Score: 3 reviews
Well I wouldn't do a PM without a billet wheel and a tune to match.....contact Nate windrunner408 for more info on billet wheels
Todd
ODAWG714 likes this.
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
post #4 of 26 Old 01-18-2014, 09:33 PM
gotta_gofast's Avatar
Quoted: 60 Post(s)
Honestly that's a lot of cash for a completely stock truck. Post up in the Wanted section and pick up a good used stock turbo. Use the rest of the money on a monitor, EGR delete, and coolant filter. It will do your truck much more good than a larger (lazy or laggy) turbo. If you want to tune, I would suggest upgrading the exhaust and installing a pyrometer.
This is just my humble opinion and remember its worth every penny you paid for it! haha
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #5 of 26 Old 01-19-2014, 02:21 AM
turbotibbo's Avatar
The pmax is a great turbo , get your self a nice tow tune from Matt at gear head , special for the pmax and you will love it . If you really wana go to town grab a billet wheel for your pmax
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #6 of 26 Old 01-19-2014, 04:20 PM
colonel angus's Avatar
Quoted: 2 Post(s)
There is a better, cheaper and easier to tune Turbo than the P-Max... PM Adrian Guglimetie he'll be straight up honest and won't try to sell you something you don't need.
He has a knowledgeable support team too call his cell in the evenings, like now....
412-926-8091
Tell Him Denny sent ya.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #7 of 26 Old 01-19-2014, 05:13 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
Pmax with single plan billet wheel would be my choice or a mtw stage 1 but gauges, monitor, exhaust, and dealing with the egr are first on the to do list. If you stay stock just add a billet wheel and you will love it. That is my two cents.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #8 of 26 Old 01-20-2014, 04:28 AM
You could also send your stock turbo to Barder Turbo Service for a rebuild and have James add a billet wheel to it.
WLDHRSE is offline
post #9 of 26 Old 01-20-2014, 09:49 AM
peixinho's Avatar
Quoted: 174 Post(s)
I would recommend buying another used turbo or going with a pmax to start with.
If you have so much play in the turbo that it has contacted the housing then it is very likely that there is no way to rebuild the core. That usually means there is play in the bearing housing and the backing plate is bad. Many turbo builders do not accept these as viable good cores to be built from. Obviously that is up to the turbo builder to decide.
A powermax is also a good option... but I would only recommend the pmax if you get a billet wheel and get some good pmax tuning for it.
You could also buy a used turbo and add a billet wheel to it
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #10 of 26 Old 01-20-2014, 10:07 AM
I use a Powermax with a single plane billet wheel and love it. I've also used a batmo wheel with it and prefer the single plane wheel and forget the stock cast wheel. The cast wheel makes a nice desk paper weight though. I also have a stock newly rebuilt core with a WW2 in it but I prefer the Pmax single plane combo due to the lower EGTs up top and the mid range egts are pretty much the same.
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
