Billet Wheel ?'s - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-18-2014, 03:25 PM Thread Starter
Sesco4's Avatar
Billet Wheel ?'s
What's my options when it comes to billet wheels. Who offers them and what is the benefits to adding one. Also what's the deal with single and dual plain wheels. I would be adding one to an 03 turbo would there be any difference in the amount of whistle by switching to one. Thanks in advance for the info.
2005 F250 CCSB 4X4
PHP Atlas 40 FICM Tune
PHP ECM/TCM Rollback
Old ECM VXCF9N4
New VXCF4N3
Old TCM TQCI1NA
New TQCI0N3
Zoodad Mod
Delo ELC Coolant
Rotella T6 w/Rev-X
Fumoto Valve F-111
2009 Rear Bumper
Newton Lifts 2.5" leveling kit
Sesco4 is offline
post #2 of 11 Old 01-18-2014, 03:34 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Whistle comes from the turbine not the compressor so there is no change in that. There is the Batmowheel, MTW, Dieselsite Wicked Wheel etc.
RIP Mitch
the Org crew
PGreenSVT is offline
post #3 of 11 Old 01-18-2014, 03:37 PM Thread Starter
Sesco4's Avatar
So is one better than the other what are the benefits etc.
2005 F250 CCSB 4X4
Old ECM VXCF9N4
New VXCF4N3
Old TCM TQCI1NA
New TQCI0N3
Zoodad Mod
Delo ELC Coolant
Rotella T6 w/Rev-X
Fumoto Valve F-111
2009 Rear Bumper
Sesco4 is offline
post #4 of 11 Old 01-18-2014, 04:48 PM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
They all tout that they do this and that over the competition. But in the end, they all work pretty much the same and I dont think anyone has noted anything drastic from one brand to the other. Id get whatever is cheapest, usually MTW.
MrOneEyedBoh is offline
post #5 of 11 Old 01-18-2014, 05:23 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
They all do this AND that? Or is it more that than this? Cause I have a lot of this but not a lot of that. I think that is what the truck needs. I don't have a CIL yet but Ive heard you can run very low on both this and that before IT hits the fan. And that aint good.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
The Following User Says Thank You to kinnisoj For This Useful Post:
sinner6.0L (01-18-2014)
post #6 of 11 Old 01-18-2014, 05:27 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
I have a diesel site one and noticed a big decrease in smoke and haze on heavy throttle, about 50-70 degree cooler egts.
2005 F350 CCLB FX4
2005 F350 CCLB FX4
juniorssrollin is offline
post #7 of 11 Old 01-18-2014, 06:37 PM
Quoted: 13 Post(s)
What I meant what that some companies theirs is far superior, some lower EGTs more than the other guys, more boost etc. But in the end they are pretty much the same. Now when you start to talk single plane vs. dual plane, I could buy into that.
post #8 of 11 Old 01-19-2014, 03:07 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 108 Post(s)
There are dual plane and single plane compressor wheels. On the dual plane wheels the advantage is weight. On the single plane it's weight and the ability to move air.
I for one don't believe in the "lowering of EGTs" part. Since the PCM monitors all kinds of parameters it will adjust for the new air flow. Lowering of EGTs theory tells me it's leaning out the air/fuel mix which could be bad or good depending on your current setup. Sure the first day of driving you may see the temps dropped but the long term will bring those numbers back up.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #9 of 11 Old 02-05-2014, 12:48 PM
Quoted: 9 Post(s)
Originally Posted by HeavyAssault View Post
TLowering of EGTs theory tells me it's leaning out the air/fuel mix which could be bad or good depending on your current setup.
That's for gasoline engines, not diesels. More air will not hurt a diesel motor because of the so called "leaning." There is no air/fuel mixture per say.
2005 Dark Blue F-250 Harley Davidson 4x4. SCT Livewire TS, 4" Silverline TBE, Sinister intake elbow, Riff Raff turbo boots, Blue spring, 6.4 banjo bolts, Sinister coolant filter, Fleetguard OAT, IPR EGR delete, ARP studs.
1998 Dodge Viper GTS. Silver/Blue stripes 1 of 21: Corsa exhaust, high flow cats, K&N filters, smooth tubes
Invasivore is offline
post #10 of 11 Old 02-05-2014, 03:34 PM
Dirty_Stroke's Avatar
I have run a turbo with a batmowheel, a single plain, and a dual plane. I can say the batmowheel is the absolute worst and do not waste any money on one. The single plain wheel REALLY woke up the turbo coming from a batmo. It almost felt like a different turbo all together with how much more off idle power and response it had. The dual plain wheel lost some of the off idle power. Enough for me to notice it. Now the throttle response is still there and after say 1800-1900rpm the dual plain wheel for sure gives a more "push you back in the seat" feel than the single plain. I would go with a single plain wheel if your towing and/or really like the peppiness from red light to red light in your truck. If you frequently hammer on it (like I do) then the dual plain is the way to go. Way more "passing gear" type power if you hammer down to pass someone or race from a rolling start.
05 F250 FX4 Lariat, SCT Livewire, 155cc injectors, Gryphon FICM tuner, ARP studs, MTW Stage 2 Turbo, Riff Raff boots, Warren Built trans, PMF traction bars ,4 inch straight pipe, Sinister EGR delete, S&B CAI, N-fab bars, level kit, 5% limo tint, 35 Toyos and 20s, Recon smoked everything, Harley headlights, 5k HID's, Camlocker toolbox, lots more
Dirty_Stroke is offline
