RCD pistons and lifters - Ford Powerstroke Diesel Forum
post #1 of 20 Old 01-18-2014, 09:43 AM Thread Starter
borsky4's Avatar
Has anyone tried the rcd oem replacement lifters and/or pistons? any feed back would be appreciated...
thnx
edit: what about these HD wrist pins, iv never heard of this but my piston did crack along the wrist pin,
http://www.rivercitydiesel.com/index...mart&Itemid=54
2006 CC SB, SRW, Barder stg #2, Ported manifold, Warren 190 30's, banks CAC, SCT Tuned by/IDP, IDP ficm tunes, nadp trans, fluidampr, FASS LP, Driven RR, edge insight, HPODS, BD ex manifolds, HD y pipe all ceramic coated & wrapped, UCF O-ringed heads with arp's, Colt stg 1 cam with RCD springs and tubes,
6" lift/trac bars, 37's 4:30 gears, Future mods: non VGT T4 64mm BASB
borsky4 is offline
post #2 of 20 Old 01-18-2014, 09:53 AM Thread Starter
borsky4's Avatar
I will be measuring my wrist pins when I get it apart for out of round
borsky4 is offline
post #3 of 20 Old 01-18-2014, 12:01 PM Thread Starter
borsky4's Avatar
Damaged piston is out and the wrist pin is thundered. Looks like ill be ordering these for my build...
borsky4 is offline
post #4 of 20 Old 01-18-2014, 12:45 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
I just read your history with your mods to the truck as I sit here in the Calgary airport hotel in the heat wave 50*f. Your truck hasn't been playing nice. You would expect the wrist pin issue to be from a sharp load on the piston from an event like a hydro-lock or uncontrolled explosion, such as from ether or extremely advanced timing. Since you live in Canada and it does get very cold in Alberta (just not today), perhaps one of the tunes has not been playing nicely either. If you have read some of my posts about cold weather and timing, I have seen upwards of 16* BTDC at start and during warm up while driving. I have also seen 14* BTDC once warmed up. JMO, but that could easily create the conditions for the piston slam that could bust it.
Too bad you have to go in for the big repair.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #5 of 20 Old 01-18-2014, 02:09 PM Thread Starter
borsky4's Avatar
Well I have never used ether on it. But you could be on to something, how do you monitor timing? dash boss? I only have edge, and I don't think I can monitor timing on it. You would think that the head gasket would blow before you bent a wrist pin and cracked a piston from timing, as that is the known weak link. I dunno. I will admit I was towing 6k on x street the day before it happened, so I was thinking that was the straw that broke the camels back. I know I am not the only one that tows on a race tune. but it wont be happening again... By the way egts never got higher the 1200ish for more then a couple seconds.
borsky4 is offline
post #6 of 20 Old 01-18-2014, 02:14 PM
Don't mind me
westcoaststrokin's Avatar
Quoted: 3 Post(s)
Unless the cold had something to do with it towing with Xstreet didn't. I have towed in Xstreet, and Looney Wild track and the truck is none the worse for wear. BTW my trailer tips the scales at about 10k loaded.
Josh
04 F350 CC SB DRW IT HAS SOME STUFF
"Idiopathic, from the Latin meaning we're idiots cause we can't figure out what's causing it." House M.D.
westcoaststrokin is offline
post #7 of 20 Old 01-18-2014, 02:18 PM Thread Starter
borsky4's Avatar
you might be riding a slippery slope, just sayin. And yea mine was 6k empty four sleds puts it up over 8k
borsky4 is offline
post #8 of 20 Old 01-18-2014, 02:24 PM Thread Starter
borsky4's Avatar
Maybe I need to get IDP to write me a winter file with a little less timing, thanks
borsky4 is offline
post #9 of 20 Old 01-18-2014, 05:50 PM
Don't mind me
Quoted: 3 Post(s)
Well the Dodge in my sig was towed in xrace and the trailer alone weighs 8k. I have been tuned since 08 so I am pretty sure I am fine.
Josh
post #10 of 20 Old 01-19-2014, 07:21 AM
Quoted: 47 Post(s)
I doubt the 6k trailer was the issue, but combined with the cold and a big foot, perhaps. For WCS, the cold we get DOES matter. With typical west coast temps, it only slightly mucks up the timing.
Frank
Working for Toys
