True twin turbo suggestions - Ford Powerstroke Diesel Forum
 30Likes
post #1 of 80 Old 01-18-2014, 03:21 AM Thread Starter
kdogg85's Avatar
I am going to be trying true twin turbos on my truck. Before the meat of the post gets going, keep the naysaying at bay, it's my money I'll waste it if I want to.
I had new heads cast with bigger ports, runners, etc.. I made my own intakes, and am working on headers( upswept block hungers that veer outward making room for the turbos.) going to run 350/150's, colt stg 2 cam, forged crower rotating assembly, you get the picture.
I was thinking start with 2 62/68/.70 t3, the small housings are to see where I stand on lighting the chargers, if they light way early and I have to gate hard, I'll step up to the t4's.
Let the suggestions(other than don't do it) commence.
sealeveloc and Gadgetguru like this.
David
05 f250 ( double your pleasure ) underway
'10 f250 ccsb 4x4, project super mom 366/515 compounds, 200hp sticks, and all the other goodies
Most importantly, the car seat mod
kdogg85 is offline
post #2 of 80 Old 01-18-2014, 04:03 AM
I love the idea of doing something different. I'm looking for a 2 door 2wd right now to do twins on, just on a smaller scale, 190's or 205's max with everything short of dual HPO pumps. I was thinking about T3's as a max starting point for mine and may have to go smaller. I hav another use for the T3's if they turned out to not work well for me. Your plan sounds like a great place to start.
WLDHRSE is offline
post #3 of 80 Old 01-19-2014, 07:15 AM
Scolesy8's Avatar
this sounds awesome....
Zach
'04 F250 6.0 with some go go
Scolesy8 is offline
post #4 of 80 Old 01-19-2014, 08:30 AM
Dirty_Stroke's Avatar
Did I miss something Kdogg? What happened to your 07 Fummins?
05 F250 FX4 Lariat, SCT Livewire, 155cc injectors, Gryphon FICM tuner, ARP studs, MTW Stage 2 Turbo, Riff Raff boots, Warren Built trans, PMF traction bars ,4 inch straight pipe, Sinister EGR delete, S&B CAI, N-fab bars, level kit, 5% limo tint, 35 Toyos and 20s, Recon smoked everything, Harley headlights, 5k HID's, Camlocker toolbox, lots more
Dirty_Stroke is offline
post #5 of 80 Old 01-19-2014, 11:16 AM
madpowerstroke's Avatar
When you say real twins do you mean one turbo per bank feeding the engine?
If so I always thought that would be a neat setup. That's a heck of a lot injectors you have decided on.
Good luck on your build
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #6 of 80 Old 01-19-2014, 12:18 PM
peixinho's Avatar
Quoted: 207 Post(s)
how about twin vgt turbos? Run one off of each bank and feed just that bank. Split he vgt pigtail. Custom tuning. Almost like having two 4 cylinder diesel engines under the hood. You could mount one in each battery spot and build two custom intake manifolds. One feeding each head. Add in some true dual exhaust. Using the vgt you could get a much larger charger spooling a little quicker. That would definitely be different! Next year if I had the money I was going to try something like this (or just do some compounds). It should be a crazy fast spooling setup that can move a ton of air... theoretically.
ODAWG714 and Scolesy8 like this.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #7 of 80 Old 01-19-2014, 02:40 PM
Scolesy8's Avatar
That sounds like an awesome idea Charlie... But what about the fact that you are now taking a turbo designed to be able to spool with X amount of air and are cutting it in half? I feel like once you got them going it'd run like a raped ape but even with a vgt would it be a little slow at first?
Zach
Scolesy8 is offline
post #8 of 80 Old 01-19-2014, 03:25 PM
peixinho's Avatar
Quoted: 207 Post(s)
The cool thing about vgt turbos is the fact that you can get a bigger than normal turbo to spool more like a smaller turbo. The downside is you lose a little bit of flow up top.
Generally speaking... take any given size turbo and make it a vgt... the vgt will spool faster and flow less air. I do not know how well it will spool to just run off of 4 cylinders, but I would venture to say that it would spool much better than any given non-vgt of that size.
Sorry for the slight derail... I am very excited either way you go
KC Turbos
peixinho is offline
post #9 of 80 Old 01-19-2014, 03:50 PM Thread Starter
kdogg85's Avatar
the fummins met a log truck and lost, badly.
I gave a little thought to the vgt side, but my concern is that given 2 different sections of wire, they do not transmit signals exactly the same, wire x may transmit .002 seconds faster than wire y. It seems you guys have enough trouble controling vgt as it is. As I've read comparing dmax and cummins to the pstrokes. Would be neat to try, just not for me.
I wanted to try 2 362's because having 1400cc(350's) per head is the same as 175's for both heads. A 362 works great with 175's. But, as Nate told me and after finally listening to him, not gonna be kosher on the surge line part of the map if all holds true.
A couple garretts were suggested but, they seem small for what needs to be cleaned up, and I'm pretty sure I'd have to gate the crap out of them. Maybe not with a more reasonable injector.
The dilemma is I'm going to need a big A$$ explosion down low to get them spinning, then I think the turbos will be fine. I have the airways and the straightest shot at the turbines a v8 will ever get. It'll be several months at least before i'm at the point to buy chargers and injectors, just getting the thread out for tips, tricks, suggestions, etc..
Yes Adrian, one charger per head, totally divorced airpaths as well.
David
kdogg85 is offline
post #10 of 80 Old 01-19-2014, 04:50 PM
6 L chevy eater's Avatar
This sounds wild!! But I like it. I know a few months back diesel power magazine had a true twin turbo 6.4 in it. And I think MPD had there hands in the build. Maybe u could find it and get an idea on charger sizes. Sounds awsome tho forsure
2004 F250 ccsb
Skint Back Motorsports
Warren-HYBRIDS-- S400
FULL Billet Twisted Diesel Built Tranny
10.90@124 on fuel dammit
6 L chevy eater is offline
