cat back vs turbo back - Ford Powerstroke Diesel Forum
Old 10-05-2008, 03:41 AM
I have a 2006 F250 and was wondering if there are any downsides to having a tb system with cat delete pipe. ie, check engine light, performance issues, etc. I am looking at the MBRP 5" system but was wondering what else you would have to do going the tb+cat delete route and any issues that may be involved. Thanks!
Old 10-05-2008, 09:27 AM
There aren't any downsides to TB exhaust. Except the loss of milage because your flooring it all day long. Niccceeee
Old 10-05-2008, 09:53 AM
With a full Turboback you might lose a little "off-the-line" power but that's it. I have a 4" TB and no way I'd do a 5". 4" is plenty unless you are going real big.
Old 10-05-2008, 12:05 PM
So it doesnt pop on a check engine light or mess with the onboard computer at all? Also, why wouldn't you go with 5", bigger looks nicer (and sounds nicer)
Thanks
Old 10-05-2008, 12:20 PM
Send a message via AIM to troid123
Thanks
Sounds nicer? Not really. And no, it will not throw a CEL.
Old 10-05-2008, 12:22 PM
sound is nearly the same i would go with 4 inch you get the same power gains and mpg gains and you save money. unless you plan on haveing over 500rwhp you dont need 5inch
Old 10-05-2008, 04:44 PM
The 6.0 monitors virtually nothing emissions related, so it's pretty hard to get a check engine light for anything exhaust related except an EGR delete, and even then only certain strategies will throw a cel.
Here's another thumbs up on the 4" turbo back. You definitely don't need the 5". FYI: Most 4" systems are 4" after the downpipe. The downpipe is usually 3.5". You can get a 4" downpipe, but it can be a real pain to install and isn't necessary. Sometimes you even have to hammer in clearance in the firewall to make it fit.
Old 10-05-2008, 04:48 PM
yah + 1 more for 4" kit... the 5" kit sounds a lil deeper and is a lil more difficult to install because of the size .....
Old 10-05-2008, 05:36 PM
Wont the 5" increase more turbo lag as well?
