What size nozzles? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 01-16-2014, 06:54 PM Thread Starter
kdogg85's Avatar
What size nozzles?
I am going to run 350cc conventionals, getting closer little by little. Anyway, would 125's work fine, or should I get the 150's I see in the few threads these injectors pop up in? Thanks guys.
David
05 f250 ( double your pleasure ) underway
'10 f250 ccsb 4x4, project super mom 366/515 compounds, 200hp sticks, and all the other goodies
Most importantly, the car seat mod
kdogg85 is offline
post #2 of 16 Old 01-16-2014, 07:00 PM
JGman141's Avatar
I'd go with the 150s for that size
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #3 of 16 Old 01-16-2014, 07:03 PM Thread Starter
kdogg85's Avatar
I would guess that's because 125's wouldn't empty the barrel fully?
David
kdogg85 is offline
post #4 of 16 Old 01-16-2014, 07:07 PM
JGman141's Avatar
I wouldn't think that a 125 could empty that entire body. Might even look into going with 200s
JGman141 is offline
post #5 of 16 Old 01-16-2014, 08:14 PM
peixinho's Avatar
Quoted: 174 Post(s)
Here is some food for thought right off of Warren Diesel facebook page
All at 4000icp
500cc 300% nozzle
Stock spool valve
2.4ms 2600rpm 340cc
So with a 300% nozzle he is only dumping 340cc of fuel. I know he has the ability to modify the spool valve to flow more fuel but when I asked him about it he did not recommend it for a daily driver.
Right now jesse is running 350/75s and dumps about 240cc of fuel
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #6 of 16 Old 01-16-2014, 09:23 PM Thread Starter
kdogg85's Avatar
I would think a 300% would be just a tad much, don't you?
David
kdogg85 is offline
post #7 of 16 Old 01-16-2014, 09:48 PM
Gearhead2012's Avatar
Quoted: 2 Post(s)
How do you actually plan on using this thing when its all done David? Is it a competition truck or just a play toy...daily driver dare I even ask?....Heaven forbid I say the word tow? lol...I cant help much on the nozzle size, just along for the show, I cant wait to see how your build turns out.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #8 of 16 Old 01-16-2014, 10:05 PM Thread Starter
kdogg85's Avatar
It'll be a dd/toy. I have another vehicle in case one of our contraptions tears up. It'll tow, my big butt around that is.
I don't mind having to be easy on the throttle for dding, but I understand its gonna smoke some, oh well that's life. Just gotta tune out what I can.
Oh, and as a teaser, the intake ports weighed in at 453cc. Exhaust is beyond top secret, just know they are a smidge larger, hehe. If they work line I hope, I'll let the design out.
But god, the fab work for this is never ending. The firewall is all good, now working around the inner fenders, then the core support area.
David
kdogg85 is offline
post #9 of 16 Old 01-16-2014, 10:09 PM
Quoted: 2 Post(s)
wow...I cant wait pics of a build of this scope lol.
Under construction
Machining the 6.0:
post #10 of 16 Old 01-17-2014, 07:59 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
You could run 100s if you're really wanting good atomization, but I don't think you'll push 350cc of fuel unless you run some rediculous timing. 100 nozzles should allow for you to dump about 260-270ccs of fuel in a 1000 shots at 4000 psi of ICP and 2.4-2.5ms of PW.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
