Innovative aggressive Street tune observations - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-16-2014, 12:39 PM Thread Starter
proamas's Avatar
Ok guys & gals I am running innovative diesel aggressive street tune. What is happening is, when the trans shifts into 3 or 5th gear the truck seems to nose down a bit. Definitely not pulling as hard. With that said I never see above 22psi in boost no matter what gear I'm in. Some readings I observed in my last pull at WOT are:
Injector pulse width is 2.44
ICP pressure max is 2129psi I know Eric does something with this so it displays a little crazy
IPR duty cycle is 74% max
Boost max 22.77 psi
My truck has 5 Reman motorcrafts, 5" from down pipe back,so I don't think I have any restrictions in flow holding boost back. I would think I should see anywhere around 28-30 psi with this.
I have deleted EGR, blue spring upgrade and the ECU strategy of VXCF9H7 I've heard this strategy will make a truck loose power too.
Any thoughts?
2006 F250 Lariat
EGR Delete
SCT Livewire with Innovative tunes
Blue spring upgrade
Sinister Coolant filter
5" Diamond Eye SS exhaust
proamas is offline
post #2 of 3 Old 01-16-2014, 02:23 PM
borsky4's Avatar
boost leak, id check the cac boots, sometimes they are hard to see, look for dust sticking to an oily mess. A mirror wil make looking at the ones on the IC easier to inspect.
2006 CC SB, SRW, Barder stg #2, Ported manifold, Warren 190 30's, banks CAC, SCT Tuned by/IDP, IDP ficm tunes, nadp trans, fluidampr, FASS LP, Driven RR, edge insight, HPODS, BD ex manifolds, HD y pipe all ceramic coated & wrapped, UCF O-ringed heads with arp's, Colt stg 1 cam with RCD springs and tubes,
6" lift/trac bars, 37's 4:30 gears, Future mods: non VGT T4 64mm BASB
borsky4 is offline
post #3 of 3 Old 01-16-2014, 02:31 PM
sprksonu's Avatar
might have a slight boost leak and also sounds like you have the 3-5 shift flare, very common issue. they make a direct drive solenoid for the trans which fixes the issue for 50% of the people. i would hit chris b up at truck source diesel and get his spd (super panty dropper) and try it out. his tunes are spot on and IMHO far superior than innovatives tunes and might even fix that 3-5 flare?
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
