hi temp powder costing - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 16 Old 01-15-2014, 06:40 PM Thread Starter
LittleRed's Avatar
Not sure if this is the right place for this question. I just bought a powerflow (grand rock) turbo back exhaust for my 6.0. The system is alumnized pipe, so can I have it powder coated with some high temp powder? Not sure if the poweder will hold up to the high temp of the exhaust? Another option would be to paint with a high temp paint. Would that be better to use? The reason for coating the exhaust is to help prevent it from rusting as I live in the north east part of ny were they use salt on the roads.
LittleRed is offline
post #2 of 16 Old 01-15-2014, 08:00 PM
Scolesy8's Avatar
ive often wondered about getting the outside of my compressor housing and my CAC pipes powder coated along with a few other parts for a nice clean looking eng. compartment. but I feel like the bang for the buck is just going to be the paint for your exhaust rather than the powder coat.... big $$$$$$$
Zach
'04 F250 6.0 with some go go
Scolesy8 is offline
post #3 of 16 Old 01-16-2014, 03:11 AM Thread Starter
LittleRed's Avatar
I have a buddy that can do the powder coating for $130. So the price is not the problem. I was wonder if it will hold up?
post #4 of 16 Old 01-16-2014, 03:58 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I would do actual ceramic coating. Most of that stuff will 1800-2000F temps with little to no problem
WLDHRSE likes this.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #5 of 16 Old 01-16-2014, 04:00 AM
I think for the price of having it powder coated spending the extra on stainless steel would have been a better move. Unfortunately everywhere you put a clamp on the system or where you weld it is going to be where it rusts through.
Diesel Equipment service manager lead technician
jpott62 is offline
post #6 of 16 Old 01-17-2014, 07:58 PM Thread Starter
LittleRed's Avatar
I can get the full exhaust powder coated for 100.00. So it is still cheaper then a stainless one. But I decided to go with the vht flame proof primer and paint as it is good up to 2000 degrees.
post #7 of 16 Old 01-18-2014, 03:35 AM
Let us know how that holds up.
WLDHRSE is offline
post #8 of 16 Old 01-18-2014, 04:47 AM
I opted for for ceramic coating, let us know how the VHT came out.
RAD69 is offline
post #9 of 16 Old 01-18-2014, 05:09 AM
BACKYARDIGAN
Quoted: 4 Post(s)
I've used that VHT paint. My heads and rocker boxes are painted in their engine enamel and it's holding up great. However though, I've used their flame proof paint on cast iron turbine housings and exhaust manifolds and even with baking it (which they recommend doing) it still flakes off. Maybe since your exhaust is not cast it'll last longer but I don't know.
Nate
post #10 of 16 Old 01-20-2014, 04:39 PM Thread Starter
LittleRed's Avatar
I will let you know how it holds up. I am spraying the exhaust Wednesday night. RAD how much did the ceramic coating cost?
